how to wire up the fans for manual switch on
Old Aug 17, 2003 | 06:51 AM
OutLuDeD's Avatar
Default how to wire up the fans for manual switch on
hey my car's cooling fan doesnt come on by itself. im thinking it would be cheaper and better to wire in my own switch. so where do i find the main power line to the fan.
Old Aug 17, 2003 | 07:50 AM
blah13's Avatar
Default Re: how to wire up the fans for manual switch on (OutLuDeD)
Find the CTS on the back of the block. It should have 2 wires running to it and a rasonably lage boot covering it. Upper left of your oil filter.
Turn the ignition on and use a paperclip or whatever to connect the 2 wires. If your fan comes on then your relay is good.
Then run a wire from any ground or your negative battery terminal. Connect it to each wire and find out which of the 2 wires it has to be connected to to turn the fan on.
Now what you do is run that ground /neg battery wire to your switch.
Then run the other wire from the switch back to whichever wire you hooked the ground to to get the fan to run.
Viola! A remote fan switch.
However if you hook up the 2 cts wires and the fan doesnt come on you'll have to find a way to bypass the relay, I sugest search.
Old Aug 17, 2003 | 09:57 AM
OutLuDeD's Avatar
Default Re: how to wire up the fans for manual switch on (blah13)
that seems like a good way to test the ralay, but im sure there is an easier way to wire in the switch, such as one of the main positive wires that go into the fan itself. any way also to check if the stock mechanism thats supposed to turn on the fan is good? where can i buy a replacement if its not?
Old Aug 17, 2003 | 11:28 AM
blah13's Avatar
Uh there isnt a much easier way then adding 2 wires for a switch.
Old Aug 17, 2003 | 01:13 PM
OutLuDeD's Avatar
ooh my bad your right, i got a bit confused b4...hehe
ever'sneighborhood
Mar 26, 2009 07:46 PM
Want2race
Jul 13, 2003 11:09 AM
st0nedstoopid
Jul 11, 2003 12:19 AM
matt j
20
Jun 17, 2003 10:00 AM
MilanoRex
Oct 5, 2002 06:52 PM
