keep blowing fuses, what's the problem!?!
i can't get a fuse in my tail light instrument fuse holder under my dash without it blowing as soon as the fuse makes contact. i tried disconecting my battery and installing the fuse but it blows when i conect the battery. i disconnected everything i installed recently but it still won't hold a fuse. what does this mean. all my other fuses work fine.
Make sure you're reading the fuse diagram correctly. Perhaps you replaced one or more fuses with the wrong ampage. Also, like the guys said above me, check your grounds, you're shorting out somewhere.
-Jeff C.
-Jeff C.
as it turns out, it was a wire from my stereo adapter shorting out the fuse. i did a search and found the exact awnser to my problem. can you imagine that?
for honda-tech
for honda-tech
