b16a distributor.......
Old Aug 16, 2003 | 06:36 PM
roadawg's Avatar
Default b16a distributor.......
I searched for the b16a distributor and it seems like the dizzy for the b16a is a common problem.
The archives are unclear about what distributor to use. I was thinking about getting one on the internet, but I want a new one.
All of you guys that had a b16a and a fucked up dizzy what did you do?
Where would I be without Honda-Tech, again thanks for the help
Old Aug 16, 2003 | 06:55 PM
EP3_05's Avatar
Default Re: b16a distributor....... (SiRWanabe)
A 90-91 integra LS distributor will work if you modify the mounting legs so you are only using 1 or 2 as opposed to the stock three legs. You can also have the distributor rebuilt but that can be costly.
Old Aug 16, 2003 | 07:24 PM
JonGP4's Avatar
Default Re: b16a distributor....... (91civic)
I have a working one, i'll sell it for 50 bucks.. IM me
Old Aug 16, 2003 | 07:39 PM
BMacls's Avatar
or you can youse the one from a 90-91 acura intregra GSR
Old Aug 16, 2003 | 08:16 PM
rioninja's Avatar
Default Re: b16a distributor....... (SI_CRX_AUTOX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SI_CRX_AUTOX &raquo;</TD></TR><TR><TD CLASS="quote">or you can youse the one from a 90-91 acura intregra GSR </TD></TR></TABLE>
or while your at it, you can use one from the hyundai excel that came with a
dohc vtec in 91. Oh wait, that doesnt exist either.
Old Aug 16, 2003 | 09:15 PM
Ef Whore's Avatar
Default Re: b16a distributor....... (rioninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">
dohc vtec in 91. Oh wait, that doesnt exist either. </TD></TR></TABLE>
Hahaha.....First ask Steve at HMO, he should warranty that dizzy....it only lasted an hour
Old Aug 16, 2003 | 09:20 PM
spooned out's Avatar
not sure if 1st and 2nd gen's are different but why can't you get one from dohc si or dohc delso vtec? when my dizzy (b16a2) went out i ordered one from Importautosalvage.com they have the info you need if i remember correctly it was from a 95 dohc delso
Old Aug 16, 2003 | 10:34 PM
Malgerus's Avatar
Default Re: (spooned out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out &raquo;</TD></TR><TR><TD CLASS="quote">not sure if 1st and 2nd gen's are different but why can't you get one from dohc si or dohc delso vtec? when my dizzy (b16a2) went out i ordered one from Importautosalvage.com they have the info you need if i remember correctly it was from a 95 dohc delso</TD></TR></TABLE>
Ist Gen B16 = OBD-O, 2nd Gen B16A = OBD-I... Not interchangeable. As for the distributor thing, I hear you can swap the guts from an 88-91 CRX Si distrobutor and be good to go.
Old Aug 16, 2003 | 11:45 PM
BMacls's Avatar
so you dont know about the b17 smart ***
Old Aug 17, 2003 | 09:00 AM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SI_CRX_AUTOX &raquo;</TD></TR><TR><TD CLASS="quote">so you dont know about the b17 smart ***</TD></TR></TABLE>
He was being a smartass because there is no such thing as a 90-91 GSR, which you think exists.
Old Aug 17, 2003 | 09:25 AM
BMacls's Avatar
Default Re: b16a distributor....... (Ef *****)
i dont know what you but i know there is a old school gsr that haves a b17 and i think it was a 92 and that might still be a obd0 car
Old Aug 17, 2003 | 09:48 AM
R6Boy69's Avatar
there was a GSR in 92 and 93... and it was OBD1...
Old Aug 17, 2003 | 10:01 AM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
Ist Gen B16 = OBD-O, 2nd Gen B16A = OBD-I... Not interchangeable. As for the distributor thing, I hear you can swap the guts from an 88-91 CRX Si distrobutor and be good to go.</TD></TR></TABLE>
Question for anyone........Is the problem with other DOHC VTEC distributors from different generations just the plugs for the wiring harness? And is the suggestion of using a 90-93 Teg LS distributor with one of the leggs chopped off, easiest because the harness plugs are the same? If that's the case, then why couldn't you just re-pin a DOHC VTEC dizzy? or does the OBD-0 vs. OBD-1/2 thing figure into this?
Anyone? Maybe I'm missing something?
Old Aug 18, 2003 | 08:03 AM
Default Re: (Mr. B in Az)
ttt. anyone?
Old Aug 18, 2003 | 08:19 AM
thecorey's Avatar
if you have a d16 distributor lying around you can chop off one of the legs and use it...it wont time perfectly..but it works..ive been using one for over 6 months
Old Aug 18, 2003 | 09:00 AM
Phatwhippin_CRX's Avatar
Default Re: b16a distributor....... (thekori)
90% of the time, you just need to change the cap and rotor..... the dizzy itself is usually good.
its not that the b16a had 'distributor problems' per se.... it's more like 'this engine has been sitting in a wharehouse/junkyard for HOW long?
Old Aug 18, 2003 | 09:01 AM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SI_CRX_AUTOX &raquo;</TD></TR><TR><TD CLASS="quote">i dont know what you but i know there is a old school gsr that haves a b17 and i think it was a 92 and that might still be a obd0 car</TD></TR></TABLE>
Man you just have all the right answers! It's OBD-1, and only in 92-93.
Old Aug 18, 2003 | 10:17 AM
RexB16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thekori &raquo;</TD></TR><TR><TD CLASS="quote">if you have a d16 distributor lying around you can chop off one of the legs and use it...it wont time perfectly..but it works..ive been using one for over 6 months</TD></TR></TABLE>
what he said.... haha, i think i was the one who told you that.
Old Aug 18, 2003 | 10:21 AM
rioninja's Avatar
You can use the internals from an si/hf or LS distributor, or rig one of them on like was mentioned. When switching internals though, the torx head screws like to snap so be careful.
Old Aug 18, 2003 | 10:26 AM
RexB16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">You can use the internals from an si/hf or LS distributor, or rig one of them on like was mentioned. When switching internals though, the torx head screws like to snap so be careful. </TD></TR></TABLE>
haha, **** those things! i remember one trying to take apart my old b16 dizzy and i ended up snapping ALL of them. so i said **** IT!, threw it against the garage door and got another one.
Old Aug 18, 2003 | 10:59 AM
rioninja's Avatar
Default Re: b16a distributor....... (RexB16)
Yeah, thats another option. haha
Old Aug 18, 2003 | 05:05 PM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">A 90-91 integra LS distributor will work if you modify the mounting legs so you are only using 1 or 2 as opposed to the stock three legs. You can also have the distributor rebuilt but that can be costly. </TD></TR></TABLE>
I have a 90 LS distributor, and by modify I'm assuming you mean cut off one of the mounting legs. The VTEC solenoid is in the way of one of the mounting legs when I try to mount the dizzy. Please specify exactly what you mean by modify.
Also, can the 2 connectors on the dizzy be taken off the original mounting position?
Are they grounded
I just called Steve at HMO, whom I got the motor from, to replace the dizzy and he said he has to "review my order and to call him back and he said he'll see what he can do". He better replace that ****, or he'll find out the power of word of mouth
Modified by SiRWanabe at 9:20 PM 8/18/2003
Old Aug 18, 2003 | 05:40 PM
roadawg's Avatar
Steve at Hmotors is replacing the distributor!!!!!!!!!
problem solved
Old Aug 18, 2003 | 06:37 PM
fourthgenhatchB17's Avatar
LMAO.
Old Aug 27, 2003 | 09:17 AM
4inspeed's Avatar
Default Re: b16a distributor....... (fourthgenhatchB17)
so if you have a 1st gen b16a dizzy, then what cap/rotor will fit it without any problems?? or, what internals match up? (sorry to thread jack) thanks to anyone who answers my question.
