Projected WHP with this Setup! Need some insight!
Old Aug 16, 2003 | 05:24 PM
mamaboy's Avatar
Default Projected WHP with this Setup! Need some insight!
I have currently aquired a B18C1 99 GSR. Below is the parts that i'm currently pieceing together. My main concern is Road Race/AutoX:
- Stock Block
- Stock Compression
- Stock Intake
1. Toda Spec A
2. Toda Campulleys
3. Toda Valve Springs
4. Toda Oil Pump Gear (RR purposes)
5. Toda Timing Belt
6. Mugen Baffled Oil Pan
1. Hytech Complete Exhaust System
1. Apexi PFC
2. FPR
1. Mocal Oil Cooler
2. Mocal Thermostat
I am pretty sure about this setup. Could somebody tell me my projected WHP.
Old Aug 16, 2003 | 05:57 PM
F1Spec's Avatar
Default Re: Projected WHP with this Setup! Need some insight! (mamaboy)
Get rid of Apexi. Get Hondata.
190whp
Old Aug 16, 2003 | 06:03 PM
mamaboy's Avatar
Default Re: Projected WHP with this Setup! Need some insight! (s2geezy)
OBD1>OBD2 is just absolutely bogus, but i guess since it's not FI i'll save a grip. S100 sounds good and absolutely cheap, set it and leave, since I don't plan to tune it myself. On my original B18B FI setup I decided to do something else since the HONDATA setup cost as much as a complete standalone ECU. I guess I'll give HONDATA a call. Thanks
190WHP sounds great.
Old Aug 16, 2003 | 09:47 PM
Mr Hammond's Avatar
a/k/a Jomo
Consider youself lucky to break 180whp. I would not expect more on stock block with some spec A's.
Old Aug 16, 2003 | 10:07 PM
mamaboy's Avatar
Default Re: Projected WHP with this Setup! Need some insight! (Mr Milano)
do you recommend the B's then? I'm attempting to keep stock driveability and idle. I've also heard the B's kill your rocker arms. can you confirm this?
Old Aug 16, 2003 | 11:34 PM
wHOAlly's Avatar
i would REALLY REALLY look into a skunk2 intake mani if i were u
Old Aug 17, 2003 | 12:47 AM
AllmotorJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">do you recommend the B's then? I'm attempting to keep stock driveability and idle. I've also heard the B's kill your rocker arms. can you confirm this?</TD></TR></TABLE>
I am running Toda B's right now. So far no problems...Runs f*ckin great!!!
Old Aug 17, 2003 | 08:53 PM
mamaboy's Avatar
which gasket will yield me a higher compression?
TolnaPunk
Jan 4, 2005 07:21 PM
mamaboy
Aug 20, 2003 02:30 PM
Montreal R
Oct 29, 2002 08:21 PM
Ink00
Oct 6, 2002 06:50 PM
