Corner Valve Cover Bolt Broke off
I searched previous posts and this sounds like a common occurance. My problem is that I broke this valve cover bolt off:
http://www3.telus.net/~morgand...t.jpg
As I understand it, I just need to remove the valve cover and then somehow remove the bolt and get a replacement from Honda or Acura.
Does it just unscrew from the head?
Do I need a special tool to remove it?
most likely ur going to need a screw extractor to get the broken bolt out. What it is, is a drill bit which u drill into the center of the broken bolt then u insert the extractor into that hole and it should spin right out. To do this ur going to need to remove the valve cover most likely, then just go to a honda dealership and purchase a new bolt. Now if u stripped the thread out in the hole ur going to need to either tap it back out or buy a helicoil kit and rethread it.
I've done this before a few times. I imagine you just over tightened the valve cover crown nut and snapped off the threaded portion of the stud. All you need to remove the stud is a deep well 10mm socket. They come in 2 or 3 different lengths, so remember than when you go to the dealer. About $3 each...
00ekcoupe
37
Sep 5, 2005 06:15 PM
