changing cam seals, help me out
Old Aug 16, 2003 | 03:00 PM
crx1856's Avatar
Default changing cam seals, help me out
one of my cam seals are leaking. when i change them, where do i position them. pushed closest to the head or the end of the cams?
Old Aug 16, 2003 | 03:10 PM
crx1856's Avatar
Default Re: changing cam seals, help me out (crx1856)
also, where do i need to put hondabond if any.
Old Aug 16, 2003 | 07:46 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1856 &raquo;</TD></TR><TR><TD CLASS="quote">also, where do i need to put hondabond if any. </TD></TR></TABLE>
NO HONDADBOND PLEASE! Just apply a little bit of silicone on the outter and inner of the cam seal. set the seal in place and fine a socket or something that will help you push it in evenly. also, make sure that the inner lip does not catch - because it may pop out the tension spring inside the seal.
Dxs
Jul 1, 2008 11:14 PM
guymosiris
Mar 22, 2007 07:19 AM
IVI
May 2, 2005 02:26 PM
diversegsr
Feb 2, 2005 08:27 AM
blueintegra90
May 18, 2004 12:47 PM
