does sci w/ out rev limiter disable your factory need to know fast
Old Aug 16, 2003 | 01:18 PM
dseriessol's Avatar
Default does sci w/ out rev limiter disable your factory need to know fast
if I buy just the sci not the sci-l will I have no rev limeter or will the cars factory limiter still work need to know asap
Old Aug 16, 2003 | 01:57 PM
dseriessol's Avatar
Default Re: does sci w/ out rev limiter disable your factory need to know fast (dseriessol)
bump please help
Old Aug 16, 2003 | 02:12 PM
untitled's Avatar
you will have no rev limiter unless you buy the module along with the timing retard module. correct me if i am wrong....
Old Aug 17, 2003 | 03:58 PM
Neukin's Avatar
Default Re: does sci w/ out rev limiter disable your factory need to know fast (88crx91integra)
up
Old Aug 17, 2003 | 04:31 PM
rice_n_me's Avatar
your rev limiter is in your ecu. Once you get the limiter removed from your ecu, you can use any adjustable rev limiter igntion boxes to control it. But, untill then, you can only set the limiter lower than factory, not any higher if you havent had an upgrade on your ecu.
Old Aug 18, 2003 | 09:22 AM
dseriessol's Avatar
Default Re: (rice_n_me)
thanks
teamjdm239
Engine Management and Tuning
10
Jul 21, 2014 07:24 PM
tenchi r
Mar 6, 2010 10:45 AM
boostedNOTHARDLY
Dec 8, 2007 10:18 AM
EGHatchy
Jul 16, 2002 02:23 PM
98R #448
Feb 25, 2002 01:20 PM
