which type of oil to use?
Old Aug 16, 2003 | 11:52 AM
sracing's Avatar
Default which type of oil to use?
i was wondering what type of oil people use for mods similar to mine. I just got done with my motor recently and now how 800 miles on it. i wasnt sure what type of oil i was gonna go with. thanks
Old Aug 16, 2003 | 11:57 AM
sikcrx80's Avatar
i think ive read somewhere befor that u should like 10w-30 for the break in then u 5w-30 after
could be wrong
anybody else know?
Old Aug 16, 2003 | 12:02 PM
sracing's Avatar
Default Re: (sikcrx80)
well ive already changed my oil twice since the 800 miles. i just wanted to know what type of oil i should use for the long run. (synthetic , syntec blend, or just regular oil) but thanks for your input.
Modified by sracing at 1:17 AM 8/17/2003
Old Aug 16, 2003 | 05:55 PM
philstireservice's Avatar
Default Re: (sracing)
anything made by Amsoil
philstireservice.com
Old Aug 16, 2003 | 06:02 PM
VTECorona's Avatar
Default Re: (Maxx44)
I've been using nothing but synthetic since I got my car and I burn maybe about 1/2-1 quart during 3000 miles. I was bone dry after coming out of the body shop for some odd reason so I threw in 2 quarts of regular oil and it's been about 3 weeks and I haven't burnt any so far. I might switch over to regular or to a synthetic blend.
Old Aug 17, 2003 | 02:56 PM
ejprimo's Avatar
Default Re: (VTECorona)
id stay away from the 5w-30 conventional oil because they tends to shear quicker than a 10w-30 conventional oil because of the extra viscosity improvers used in the 5w oils. for the best advice i suggest you go onto bobistheoilguy.com and ask your question there.
personally i use ACEA A3 0w-30 castrol syntec, and ive done an used oil analysis on this oil after 5200 miles and my b16a motor showed only single digit wear numbers. this oil is thicker than mobil 1 10w-30 which is only ACEA A1 because of its lower viscosity.
85mm LS VTEC
Nov 10, 2004 01:36 PM
londa hover
Mar 17, 2004 12:09 PM
crxhybrid1320
Feb 7, 2003 05:22 PM
piotrush
May 7, 2002 05:12 AM
zmeli
Aug 31, 2001 09:58 AM
