Going Turbo, Should I Buy T60-1 T4 Dual Ball Bearing or T3/T4 ? .........
Old Aug 16, 2003 | 08:04 AM
Showoff's Avatar
Default Going Turbo, Should I Buy T60-1 T4 Dual Ball Bearing or T3/T4 ? .........
I Going Turbo need help on which Turbo should i go with T3/T4 or T-60-1 here is my list of part to buy can any one give me some info on what to change or not to...
(H22A into an 1995 Accord)
Arias Pistons (9:1)
Crower Rods
AEM Cam Sprockets
SuperTech Valves
Eibach Valve Springs
Crower Retainers
<U>Innovative Turbo 60-1 T4 Dual Ball Bearing</U>
Tubular Turbo Manifold
Tail wastegate
Tail Blow Off Valve
XS Intercooler
Apexi AVCR Boost Controller
should i get a smaller turbo for faster spool up? anyone that owned these turbo's can you leave some feed back
thanks
Old Aug 16, 2003 | 08:32 AM
matix's Avatar
Go with the T3/T4 . My freind just put one in his 240 and it spools up pretty quick.
Old Aug 16, 2003 | 09:04 AM
twkdCD595's Avatar
Default Re: (matix)
t3/ 60-1 in my opinion... or a precision unit... sc61 or 63 maybe (drool)
btw I have a version of the garret t3/ 60-1 I use... been slightly worked though.
if you can afford dual BB... thats your obvious answer. t4 is big but thats what you want right.
gonna have to sleeve that block and think about serious fuel management to make use of the turbo that big. and think big injectors too.
Old Aug 16, 2003 | 10:42 AM
carolinaACCORD's Avatar
Default Re: (twkdCD595)
Do all you said, plus just a basic head port and polish, then go with the Precision SC63 snail. That, with some good dyno tuning, will be more power than you will need.
Old Aug 16, 2003 | 11:27 AM
Showoff's Avatar
Default Re: (carolinaACCORD)
yea im going with the rest of the basics, just trying to figure what size turbo to use, more for street use then drag something street/drag use not full drag
Old Aug 16, 2003 | 02:04 PM
booja's Avatar
i would go w/ the 60-1... thats what i have. i had a t3/t04b also.
my friend has a t3/t4 on and only made 273 at the wheels at 14psi.
my car is still being built but my tuner said 300hp to the wheels is easy w/ a 60-1. he said i should hit it w/ 10psi... still spools quick cuz mine is a t3 60-1
Old Aug 16, 2003 | 08:37 PM
v4lu3s's Avatar
RTFM
i would stick with a t3/t04b or e since youwant a street turbo.
if you want more peak power get the 60-1 or something like that but a well sized e or b will make 270-370 hp and spool quickly.
Old Aug 16, 2003 | 11:28 PM
Eurorider1's Avatar
Default Re: Going Turbo, Should I Buy T60-1 T4 Dual Ball Bearing or T3/T4 ? ......... (Showoff)
ya dude go t3/t4 they are the bomb turbos on the h22
Old Aug 17, 2003 | 03:39 AM
slrh22hatch's Avatar
If you are going to be using the turbo for mainly street I would go with the t3t4. Dont go with the 60-1 unless you are putting out a lot of power. If you are only boosting like 8 to 12 lbs dont use the 60-1. The t3t4 will spool up faster.
StevieR
Feb 15, 2011 08:15 PM
PeakBoost
Nov 17, 2005 07:27 AM
Showoff
Aug 25, 2003 08:56 AM
