steering wheel clicking
Old Aug 15, 2003 | 10:34 PM
jdb336's Avatar
Default steering wheel clicking
hi i have a 1991 crx dx and recently it has been clicking when i turn corners. it only does it about half way into the turn intil i straighten out the wheel again. if you know what is wrong or how to fix it please post an answer. thanks
josh
Old Aug 15, 2003 | 10:41 PM
JonGP4's Avatar
Default Re: steering wheel clicking (jdb336)
its ur axle, do a search and u'll find out more info on it.. pretty common problem
Old Aug 15, 2003 | 10:47 PM
jdb336's Avatar
thanks
Old Aug 16, 2003 | 04:37 AM
streetlegal gocart's Avatar
actually its the cv joint(most likely outer) on the axle assembly, but it is just as cheap to replace the whole axle. You don't need to empty the tranny oil to replace the driver's side, but you do for the pass. As long as your alignment isn't off, you can drive it like that for a while.
ShinyNewPenny
Aug 7, 2010 07:11 AM
niceprelude
Dec 13, 2008 10:02 PM
Jizzmaster Zero
12
Jun 16, 2006 02:42 PM
CunninLynguist
May 7, 2003 11:54 AM
BlackAckeR
Oct 29, 2001 12:08 PM
