Bitch pin is easy my ass!! (rant inside)
Old Aug 15, 2003 | 02:43 PM
gocivicgo's Avatar
Default Bitch pin is easy my ***!! (rant inside)
I know some of you gusy have been lucky and sopposedly it came out easy, but6i have been hammering for 2 freakin hours nwo and it hasnt moved one bit. Im either gonna cut my linkage or........drill the little bitch out.
Unless someone has a better helpfull idea for me???
Old Aug 15, 2003 | 02:49 PM
DohcVtecCrx's Avatar
Default Re: Bitch pin is easy my ***!! (gocivicgo)
Did one the other day, totally rusted in. Got it out in 5 minutes and all we had was a phillips screw driver and a sledge. Don't be a bitch, get mad, get off ur damn computer and go hammer the ******* thing out.
Old Aug 15, 2003 | 02:50 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I take it you are laying on your back in the driveway?
Use some jackstands,get it high enough in the air that you can get a good swing
with the hammer...Soak it in penetrating oil like P-B blaster.. Use the largest punch that will fit in the hole..Using too small of a punch will only cause the pin to expand..If all else fails,get a bigger hammer.
Old Aug 15, 2003 | 02:54 PM
SloCivicHMM's Avatar
Default Re: Bitch pin is easy my ***!! (88DXCRX)
They don't call it "the BITCH PIN" for no reason...
yeah get a good swing going.... huge punch so it does not expand...PB blaster is your friend!!!!!!!!!!!!!!
Old Aug 15, 2003 | 02:55 PM
gocivicgo's Avatar
The car is on jack stands , but i ahev the tranny restinbg on the ground in the engine bay and im hammering down on it.....still wont come out.
Old Aug 15, 2003 | 02:59 PM
88DXCRX's Avatar
Unbolt it at the shifter and drag it out in the open so you can really beat the crap out of it..
Old Aug 15, 2003 | 03:06 PM
shortyz's Avatar
yeah u can unbolt the linkage at the other end then pull whatever your doing..
get an air chisel and make a bit for it. best thing i have ever made. dont **** around with a hammer.
Old Aug 15, 2003 | 03:16 PM
E-AT_me's Avatar
Default Re: Bitch pin is easy my ***!! (shortyz)
dude, use an 8mm pin punch. should pop right out. gotta use the right tools for the job.
Old Aug 15, 2003 | 04:02 PM
Outsane's Avatar
Default Re: Bitch pin is easy my ***!! (Rexman)
if your too cheap to buy a 8mm punch, use a 10mm bolt, the shaft is 8mm.
Old Aug 15, 2003 | 04:31 PM
GirlieRacer7o2's Avatar
Stop being cheap and go buy a pin punch Go to sears and buy one from Craftsman.
Old Aug 16, 2003 | 02:52 PM
Sneaky Ef's Avatar
i'm not sure the proper width, but i have a 3 foot bar, (it acctually a drill bit with an extension) i hit it upside down, but its perfect for this, go from the top, and WHAIL it, pop out in 2 seconds
Old Aug 16, 2003 | 03:35 PM
civickiller's Avatar
Default Re: (Sneaky Ef)
what i did was i got a gear puller and put my cresent wrench above to hook on the gear puller and just used the screw on the puller to push it out. i got it out but i also broke the gear puller center bolt on the bitch pin. i tried the punch thing and it didnt work for me
Old Aug 16, 2003 | 05:55 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rexman &raquo;</TD></TR><TR><TD CLASS="quote">dude, use an 8mm pin punch. should pop right out. gotta use the right tools for the job. </TD></TR></TABLE>
After 40 minutes of banging on it with a phillips head and hammer, We went to Pep Boys bought an 8 MM punch, 5 minutes later .......voila. LOL
Spend the $ 2-3 believe me it's worth way more than that. LOL
HTH
PS Load on some Permatex "Never-Sieze" before you put back in.
Old Aug 16, 2003 | 07:02 PM
HandCommand's Avatar
Default Re: Bitch pin is easy my ***!! (4crx4me)
Use can also use a 5/16" punch if you dont have a 8mm Metric Punch.
z6hatchboy
16
Aug 6, 2009 07:59 AM
damn_import_culture
16
Sep 13, 2006 01:11 PM
577HondaPrelude
19
Apr 1, 2006 06:45 PM
sivik2nr
Jan 15, 2003 08:38 AM
dvp95
Jan 10, 2003 05:42 PM
