4.7 FD and long drives
Old Aug 15, 2003 | 12:01 PM
Rhetoric's Avatar
Default 4.7 FD and long drives
I have a 4.7 fd in my itr trans. My tires are 205/15/50. Driving at 80mph, I'm just about at 4600 rpm. I have only driven my car within the bay area. Longest drive probably is the track (75 miles away).
My question is: Has anyone (with 4.7fd and 205/50/15's) driven their car long distance? I would like to drive my car to San Diego, but I do not want to be driving 60mph for almost 500 miles. Any overheating issues, etc.? I usually drive to San Diego at 85-90mph in my other car, but in the r, that would be at almost 5000rpm.
Old Aug 15, 2003 | 12:12 PM
AssPenny's Avatar
Default Re: 4.7 FD and long drives (Rhetoric)
4.9 FD. Drove from South Florida to Michigan for Expo 02 about 5k round trip including detours. Then drove about the same distance to PA for Expo 03. Many trips to Atlanta and NC. No problem at all, just keep it out of vtec to save gas, which for me is right around 95mph.
I've also average over 110mph going to NC one night and had no over heating problems at all. However, I got around 18 mile per gallon
Old Aug 15, 2003 | 12:16 PM
Chris N's Avatar
1. You get great gas mileage in the 4-5K RPM range, as long as you aren't set to be in vtec somewhere in the range (like those with the mugen ecu).
2. The car is in no way under 'extreme pressure' while cruising on the highway for hours on end.
I would not be concerned with the rpms you are turning. Those who get longer 4th and 5th gears to lower their rpm's on the highway are, IMO, ludicrous. Anyone who actually thinks there is much (if any) difference between 4600 and 4000 rpms on the highway (as far as strain on the engine), is loony.
On the trip to the expo, it was mid 80's, humid, the car was packed down with 300lbs + of equipment/tires/jack stands/tools/jack, etc and my temp gauge never budged past just under half, nor did i expect it to.
I don't see any issues with driving 80-90 on the highway for a long time. 4-5K is pretty normal for these engines. Just drive, make sure your oil levels and coolant are ok, nothing bad will happen.
Old Aug 15, 2003 | 12:21 PM
Cosworth's Avatar
I've got no clue on 4.7FD.
But, I can tell you that crusing at 5,000+ rpm for a long period of time is complete fine with the R motor.
I've drove eight hours straight to Ft. Lauderdale, FL doing a hair over triple digits. Also, done the same to MD (9 hours straight). The only stops were for gas refill.
As long as your FD is installed correctly, you shouldn't have any problems. Oh, 205/50/15 has a bit shorter sidewall, so your speed will read faster than it really is.
Old Aug 15, 2003 | 12:22 PM
Austin's Avatar
Default Re: 4.7 FD and long drives (Chris N)
I just did an 8 hour drive on the 4.785:1, no issues what so ever. averaged 27-29mpg depending upone various circumstances.
Austin
Old Aug 15, 2003 | 12:26 PM
Bbasso's Avatar
Default Re: 4.7 FD and long drives (Cosworth)
I have the stock 4.4 and when I take long trips my tach is usually in the high range (over 5k) for hours at a stretch sometimes for entire tank full.
I have never seen my Temp move not once- even on the track.
But after a long fast drive I change the fluids.
Old Aug 15, 2003 | 12:46 PM
98R-1144's Avatar
Default Re: 4.7 FD and long drives (Bbasso)
i've done trips with the 4.7...you're fine as long as you keep it off of vtec
Old Aug 15, 2003 | 01:41 PM
92TypeR's Avatar
FSAE
Default Re: 4.7 FD and long drives (98R-1144)
Longest I've traveled on the ATS was about 5 hours. Average highway speed was about 80, and there was no sign of any engine problems. Our motors are made to handle RPM's, and ~5000 is nowhere near high in terms of RPMs when compared to what they CAN handle.
Do check your fluids before you leave. Make sure you have sufficient oil and coolant and you will be good to go
Old Aug 15, 2003 | 01:42 PM
Rhetoric's Avatar
Whew....Thanks for all of the input and experiences! I guess its time to take this baby to San Diego.
Old Aug 15, 2003 | 01:55 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric &raquo;</TD></TR><TR><TD CLASS="quote">I have a 4.7 fd in my itr trans. My tires are 205/15/50. Driving at 80mph, I'm just about at 4600 rpm. I have only driven my car within the bay area. Longest drive probably is the track (75 miles away).
My question is: Has anyone (with 4.7fd and 205/50/15's) driven their car long distance? I would like to drive my car to San Diego, but I do not want to be driving 60mph for almost 500 miles. Any overheating issues, etc.? I usually drive to San Diego at 85-90mph in my other car, but in the r, that would be at almost 5000rpm. </TD></TR></TABLE>
I've gone from San Diego to LA every weekend this month with 4.78 final and Azenis 205-50-15's, no problems, and my fan wasn't working either
Old Aug 15, 2003 | 04:27 PM
baonest1's Avatar
hey rhetoric.. are you at 70mph at 4000RPM?? i have a 4.7FD with a CDN guage cluster. the cluster looks/reads pretty accurate.
80mph for me is around 45-4600 RPM.
Old Aug 17, 2003 | 09:24 AM
Rhetoric's Avatar
Default Re: 4.7 FD and long drives (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">hey rhetoric.. are you at 70mph at 4000RPM?? i have a 4.7FD with a CDN guage cluster. the cluster looks/reads pretty accurate.
80mph for me is around 45-4600 RPM.</TD></TR></TABLE>
Yeah, Im approx. around what youre at.
Old Aug 17, 2003 | 09:55 AM
baonest1's Avatar
Yeah, Im approx. around what youre at. </TD></TR></TABLE>
Old Aug 17, 2003 | 10:06 AM
chad's Avatar
Moderator
4.785 from az to ca to sc to pa to sc.....average 85 mph and 31.2 mpg.....in a civic loaded with everything i own....over 3000 lbs in the car....i used the vafc to lean out the fuel....to get better milage!
Old Aug 17, 2003 | 12:17 PM
all stock's Avatar
Default Re: 4.7 FD and long drives (chad)
that sounds so strange people.
People with US ITR's or 96 spec ITR's with 4.7 FD should be around 5k rpm at 80mph in 5th because of the shorter gearing in 4th and 5th compared to a 98 spec tranny.
Old Aug 17, 2003 | 05:17 PM
92TypeR's Avatar
FSAE
Default Re: 4.7 FD and long drives (all stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">that sounds so strange people.
I'm at exactly 5000 rpms (actually 4950 +\- with my datalogger) at 80mph with the ATS FD in my '96 spec JDM ITR tranny.
1GreyTeg
Jul 29, 2011 01:13 PM
adrian1281
Aug 18, 2007 12:09 PM
SkyeC
13
Mar 10, 2004 01:32 PM
sjasmund
Nov 3, 2001 05:13 PM
47, 80, fd, itr, mph, rpm
