5spd swap...... my tranny mount sits too high?
Old Aug 15, 2003 | 10:25 AM
NXAccordTO4B's Avatar
Default 5spd swap...... my tranny mount sits too high?
Hey guys, i finally had time to finish my 5spd swap in my accord. I have only one problem. My tranny mount on my tranny sits a little bit too low and it causes my motor is sit high on the pass. side. I have a 97 accord with a 93 tranny. thanks
me
i did buy the 93 welded part for the 5spd and the 97 welded part for the 5spd neither looks like it will work. also, I only need to space it about 1 1/2 inchs lower to get the motor to sit right..... any suggestions?
thanks
Old Aug 15, 2003 | 11:05 AM
ArchAngel Sabastian's Avatar
New User
no help but uh whyd you use the 93 tranny?
what is 93 welded part?
Old Aug 15, 2003 | 03:21 PM
Superorb's Avatar
ok, when i did my swap, i have a 95 accord w/ 96 tranny.
i used a 5th gen tranny mount and bracket from an accord, for 5sp.... you need to have the front and rear mounts be 5sp mounts as well for it all to sit right, and im sure the driver side wouldnt hurt either, but its an expensive liquid filled one... just stick some washerd bn the mount bracket and the tranny to hve the motor/tranny to sit lower in the bay. i just thought of that now, and i might try that one day, but i havenmt had any other axle problems or anyhting like that.
Old Aug 17, 2003 | 05:33 AM
SearchBeforeUPost!'s Avatar
Default Re: (Superorb)
what is the tranny mount? a 93?
the tranny mount is the one bolted to the tran. It may differ from 4 to 5g.
Old Aug 17, 2003 | 06:40 AM
Superorb's Avatar
it does differ from gens... u CAN use the BRACKET only from a 4th gen prelude, its the same part number, but get the actual mount for yur year accord.
Old Aug 17, 2003 | 07:28 AM
ok, guys i fix the problem, i pick up a 96 tranny and mounts. I pulled the 93 tranny out and put the 96 tranny in. Car should be running in a day or so
Old Aug 17, 2003 | 12:02 PM
soysauce021's Avatar
how hard was the swap...i've been looking into this for a while now.
Old Aug 17, 2003 | 02:19 PM
Default Re: (soysauce021)
its pretty easy when u have everything........ let me know if ur going to do the swap i have all the stuff u need......... I got two of almost everything when i did my swap.. I just finish today......... bolting everything back together now..
Old Aug 19, 2003 | 08:41 AM
soccerstudj's Avatar
Default Re: 5spd swap...... my tranny mount sits too high? (NXAccordTO4B)
hey, would you happen to know what components i'll need besides the tranny to swap my 2002 accord automatic transmission with a 5 speed? thanx!
Old Aug 19, 2003 | 01:54 PM
Default Re: 5spd swap...... my tranny mount sits too high? (soccerstudj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccerstudj &raquo;</TD></TR><TR><TD CLASS="quote">hey, would you happen to know what components i'll need besides the tranny to swap my 2002 accord automatic transmission with a 5 speed? thanx!</TD></TR></TABLE>
seems like it would just be easier to trade it in for a 5 speed.
ragnarok0mega
Jul 23, 2009 08:51 AM
remaxxxk
Jan 16, 2006 06:54 PM
Sonny30
Jun 29, 2005 10:19 AM
Rob_Dog
Nov 13, 2004 10:44 PM
humtake
Apr 29, 2003 04:19 AM
