crx w/b16 turbo setup advice
What turbo/turbo size would be best for my crx hf with a b16?? i want something that will get me into the 350-400+ hp range..hoping to hit 11's or very low 12's w/o slicks or drag radials..its gonna be daily street driven, so hope that helps..right now the only thing that i plan on doing to my block is put low compression pistons, eagle or crower rods, and bearings..what compression do you think i should run?? btw, i only plan on running 93 octane..
I would say an sc57 would be a good choice as far as the turbo, and 9.1 seems to be a pretty stought but good compression to run. U could prob get 350-400 on 12-15 ibs. As long as you run a nice fuel set up and egine mangement you should be straight.
Lee
Lee
damn 350-400 whp....with only low compression pistons?? damn i kinda think that's really pushing it. while you're at it you might as well change the rods too. better safe than sorry. also running on 93 octane and making that much power takes real good tuning!! but non the less, good luck with your build up.
a regular ol' garrett will cure your problems. Precisions are nice as fudge, but for maxing out at 400, I'd just use a regular garrett...
IM for questions
IM for questions
CRXherbie91
May 25, 2008 08:23 AM
hotimportcrx
Mar 5, 2005 05:08 PM
