someone on here wanted me to scan a page out of my manual for them
Maybe it was me? I was looking for info on changing out the alternator for a 91 Civic Dx HB, 1.5L engine. Thanks for any info.
1. disconnect the ground wire from the battery negative terminal.
2. disconnect the alternator connector from the alternator.
3. remove the terminal nut at the WHT wire from the B terminal.
4. remove the adjusting bolt and alternator nut, then remove the alternator belt from the alternator pulley.
5. remove the alternator through bolt, then remove the alternator.
6. if necessary remove the mount bracket bolts and the upper and lower mount brackets.
7. adjust the alternator belt after installation.
alternator belt adjustment
1. apply a force of 22lb and measure the deflection between the alternator and the crankshaft pully.
deflection 9-11mm (0.35-0.43in)
note: on a brand new belt, the deflection should be 7-9mm (0.25-0.35in) when first measured.
2. loosen the alternator adjusting bolt and nut.
3. move the alternator to obtain the proper belt tension, then retighten the adjusting bolt and nut.
3. recheck the deflection of the belt.
Thanks alot for the info, does the maual happen to tell you what tools you'll need for the job? Also, how do I check the deflection of the belt? Thanks again.
dont_tri
18
Sep 12, 2007 08:58 PM
