Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
oil cap not screwed in, mess on engine...
Old Aug 15, 2003 | 05:29 AM
Civic44's Avatar
Default oil cap not screwed in, mess on engine...
My oil filler cap was loose and i stupidly got oil all over the driver side of the engine last night. There was alot of it on the master cylinder, motor mount, some on the timing belt cover... Fortunately i didn't drive like this for long. I cleaned up as much as I could see with shop towels... I have a race tomorrow and we're leaving tonight. Is there anything I should be taking apart to clean, or is this no big deal? Since I had just added oil, I know that less than half a pint total had been spilled. I'm at the office today and can't get to the car until later anyway. Thanks.
Old Aug 15, 2003 | 06:21 AM
Warren's Avatar
Wrong-Way Wang
Default Re: oil cap not screwed in, mess on engine... (Civic44)
Degreaser and brake cleaner are your friend.
Good luck getting it off if it's Redline.
Warren
Old Aug 15, 2003 | 06:30 AM
Civic44's Avatar
Default Re: oil cap not screwed in, mess on engine... (Warren)
It's not Redline, I can't afford that fancy stuff. It's Quaker State or something...
Old Aug 15, 2003 | 07:00 AM
Evan55's Avatar
can the oil cause damage to hoses, etc under the hood?
Old Aug 15, 2003 | 07:04 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: oil cap not screwed in, mess on engine... (elgorey)
Not as far as I know, something similar happened to me.
My dipstick tube came loose and oil squirted everywhere for quite a while before I figured out what had happened - I thought I had just spilled a lot of oil on my header.
Nothing bad happened, and that was a long time ago.
Old Aug 15, 2003 | 07:12 AM
Warren's Avatar
Wrong-Way Wang
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elgorey &raquo;</TD></TR><TR><TD CLASS="quote">can the oil cause damage to hoses, etc under the hood?</TD></TR></TABLE>
Only if it sits on rubber parts for an extended period of time (like months or years).
Warren
Old Aug 15, 2003 | 08:35 AM
Shortbus's Avatar
A couple cans of brake clean and a drip pan might do the trick.
Old Aug 15, 2003 | 08:45 AM
Jimmy L's Avatar
Default Re: oil cap not screwed in, mess on engine... (Shortbus)
Cover your distributor with a plastic bag. Spray full strength simple green everywhere in your engine bay. Wait 5-10 minutes then rinse it all off with your water hose. Let it dry and you are in business.
Old Aug 15, 2003 | 11:04 AM
BluGTIVR's Avatar
Default Re: oil cap not screwed in, mess on engine... (Jimmy L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy L &raquo;</TD></TR><TR><TD CLASS="quote">Cover your distributor with a plastic bag. Spray full strength simple green everywhere in your engine bay. Wait 5-10 minutes then rinse it all off with your water hose. Let it dry and you are in business.</TD></TR></TABLE>
I second this method
Old Aug 15, 2003 | 11:43 AM
SloCivicHMM's Avatar
Default Re: oil cap not screwed in, mess on engine... (BluGTIVR)
lil OT...does Simple Green harm paint at all?? The reason I ask is that I panted my valve cover and my intake manifold and I don't want the paint "*******" up...thanks guys.....
Old Aug 15, 2003 | 01:58 PM
4WDrift's Avatar
Default Re: oil cap not screwed in, mess on engine... (SlowCivicHmm)
It can cause wax streaks, test a spot first.
Old Aug 15, 2003 | 02:03 PM
.RJ's Avatar
.RJ
Better yet. Get one of those garden sprayer things - fill with simple green, attach hose and have at it.
RJ
Old Aug 15, 2003 | 02:33 PM
Maengelito's Avatar
Default Re: oil cap not screwed in, mess on engine... (.RJ)
i have used simple green many times in the engine bay and can attest to its badassness...
-brian
Old Aug 15, 2003 | 03:12 PM
Shortbus's Avatar
Default Re: oil cap not screwed in, mess on engine... (Maengelito)
This stuff kicks *** as well....
I think it works better than Simple Green. Believe that it's safe with paint, but you've got to watch out for contact with aluminum. It'll etch it for sure. Used wisely, it's great stuff.
Old Aug 15, 2003 | 05:39 PM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
do the simple green trick. it works my friend.
Old Aug 15, 2003 | 05:46 PM
AmginE's Avatar
alternator also, right?
Old Aug 15, 2003 | 05:59 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shortbus &raquo;</TD></TR><TR><TD CLASS="quote">I think it works better than Simple Green. Believe that it's safe with paint, but you've got to watch out for contact with aluminum. It'll etch it for sure. Used wisely, it's great stuff. </TD></TR></TABLE>
It may be safe with paint, but its not safe with wax, therefore making your painted fender look like *** until you polish/wax it again. Stick with simple green.
Old Aug 15, 2003 | 07:04 PM
JustChou's Avatar
Umm...what about the uhh...engine?
Old Aug 15, 2003 | 07:07 PM
.RJ's Avatar
.RJ
Default Re: oil cap not screwed in, mess on engine... (JustChou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustChou &raquo;</TD></TR><TR><TD CLASS="quote">Umm...what about the uhh...engine?</TD></TR></TABLE>
Never had a problem. Rinse with water first, then spray simple green. Get out hte scrub brush. Wash, rinse, repeat.
Old Aug 16, 2003 | 04:48 PM
Want2race's Avatar
go buy 3 or 4 cans of GUNK and spray it on... Let it sit 10 min and hose it off... Works everytime!
Old Aug 16, 2003 | 05:03 PM
Arsenal's Avatar
Default Re: oil cap not screwed in, mess on engine... (Want2race)
yep, can't go wrong with the good old Gunk.
dlee9
Apr 11, 2007 08:04 PM
stareatsun
Mar 31, 2006 03:28 PM
Mugen1320
Nov 4, 2005 12:38 AM
wm5holla
10
Mar 24, 2003 11:00 AM
FlipboiGSR
Aug 24, 2001 07:41 PM
