Need Help Only Getting 150 Miles on a full tank of gas!!!
Old Aug 11, 2001 | 10:53 PM
E46M3CB's Avatar
Default Need Help Only Getting 150 Miles on a full tank of gas!!!
I have a 96 JDM ITR Complete Swap in my G3 Sedan. Running Spoon ECU. Yes I am driving hard however even so I should at least get 200 miles but I am only getting 150 miles off a full tank going into my reserve. Does anyone knows why?
Here is a list of my mod:
96 JDM ITR Complete swap
JDM 4-1 Header
Catco Hi-Flo Cat
Apexi N1 Cat
Apexi V-afc (but i have not messed with any of its settings)
AEM CAI
AEM FPR Setting is at 56psi
AEM Fuelrail
Spoon ECU
Skunk 2 Cam Gears Setting is at 0 degrees
Timing is not advanced either everything is stock.
I have also changed the spark plugs .
Please help this is very frustrating... TIA
Nam Tran
Old Aug 11, 2001 | 11:06 PM
itrsport.com's Avatar
Default Re: Need Help Only Getting 150 Miles on a full tank of gas!!! (serenity)
Shift at or before 3,500 RPM 90% of the time and you'll travel more miles on a tank of gas.
Here are the results from my R - 28 MPG average.
http://members.aol.com/josh3030/fuel.html
Old Aug 11, 2001 | 11:07 PM
sgT's Avatar
sgT
VAFC and Spoon ECU.
remove both and mpg should go up to at least 25
better than the 10-15 you are getting now.
Old Aug 11, 2001 | 11:18 PM
E46M3CB's Avatar
Default Re: Need Help Only Getting 150 Miles on a full tank of gas!!! (sgT)
I have shifted before 3500 and still no result or diff...
As for reomving the V-AFC and Spoon ECU. The V-AFC has not been messed up with at all. IT's all stock settings. As for teh Spoon ecu I don;t have the stock one to even test it out... So is this the cause tho?
Thanks
Old Aug 11, 2001 | 11:21 PM
sgT's Avatar
sgT
I have seen VAFC cause 15hp loss with no setting changes.
I would take it out and see.
Sell the spoon ecu and get a regular ecu.
Old Aug 11, 2001 | 11:23 PM
E46M3CB's Avatar
As for teh V-afc Is it even possible to start up the car if teh V-afc is disconnected? I will give it a try to see if there is a change. Thanx
Old Aug 11, 2001 | 11:25 PM
sgT's Avatar
sgT
no. you have to take out the entire VAFC harness.
You also realize that the spoon ecu is probably an open loop ecu meaning
that you will get HORRIBLE gas mileage anyway right?
Old Aug 12, 2001 | 09:03 AM
Akira-R's Avatar
How did you adjust your Fuel Pressure?
I forget how you are supposed to adjust it, but I think you have to close the vacuum line or something.
Can someone please comment some more on that to make sure he adjusted it right?
thnx,
--reid
Old Aug 12, 2001 | 09:17 AM
Dr Pooface's Avatar
Default Re: Need Help Only Getting 150 Miles on a full tank of gas!!! (Akira-R)
sgT...What does "open loop ecu" mean?
[Modified by Dr Pooface, 6:17 PM 8/12/2001]
Old Aug 12, 2001 | 09:20 AM
sgT's Avatar
sgT
Default Re: Need Help Only Getting 150 Miles on a full tank of gas!!! (Dr Pooface)
It means that while cruising the computer doesnt read a/f ratio and try to keep
it stoich. This means that it just runs rich all the time, hence bad mpg
Old Aug 12, 2001 | 09:21 AM
Dr Pooface's Avatar
Thanks man.
Old Aug 12, 2001 | 10:16 AM
mickey513's Avatar
Sounds like you are running rich. Do you smell gas when you get off the car? If you do, then you are running rich. First thing I would do is do what the last guy said, and also check your O2 sensor. If it's bad, you should replace it with a OEM one, not a aftermarket. Also, the FPR might need adjusting. Plus you might want to run back on NGK spark plugs.
Old Aug 12, 2001 | 10:50 AM
sgT's Avatar
sgT
Default Re: Need Help Only Getting 150 Miles on a full tank of gas!!! (mickey513)
O2 sensor isnt going to do anything in this case because the ecu ignores it.
DOHCgarage919
Dec 27, 2007 12:03 PM
E46M3CB
Oct 21, 2003 08:03 PM
Eurasia00
May 27, 2002 09:16 PM
E46M3CB
Aug 14, 2001 09:30 PM
E46M3CB
Aug 12, 2001 08:04 AM
