im planning on buying some used 16' chrome rims cec
Old Aug 11, 2001 | 10:24 PM
94autotegLS's Avatar
New User
Default im planning on buying some used 16' chrome rims cec
I want to know if i can expect better performance , i will probably buy some nittos i weighed each rim and they weigh 20lbs each also i probably wont be able to drop my car for a month will there be any problems with ride height (too high?) or ride quality i currently have 14's stock wheels they suck ***!!!!
Old Aug 11, 2001 | 10:32 PM
leechungsr's Avatar
Default Re: im planning on buying some used 16' chrome rims cec (94autotegLS)
maybe you need to check out SuperHonda.Org. heh heh heh
Chrome rims do not help your performance. If anything, it'll slow your car down. A good set of tires will help you stick on the road better though. Nitto 555rs are nice drag radials, but wear fast. Nitto's 450 will last longer, but I hear terrible stories about terrible traction. If you want cheap tires that handle, look into some Kumho Ecsta Supras..
If you want to know if the new wheel/tire combo will make or reduce fender gap..here's a nifty equation.
Stock GSR tires = 195/55/15
195 = 19.5cm = width of tire
55 = aspect ratio of sidewall to width of tire
15 = wheel size
2" = 5cm
19.5cm X 55% = 10.725cm
10.725cm/N = 5cm/2"
10.725cm(2") = 5cm(N) (cross multiplication)
4.29" = N = sidewall height
(4.29" X 2) + 15 = 23.58 = overall diameter
Old Aug 11, 2001 | 11:32 PM
Andrea_Aunie's Avatar
New User
From: work in Tennessee and live in Georgia, from Tampa, Florida, USA
everytime he comes around yo' corna BLING BLING
Old Aug 11, 2001 | 11:42 PM
brinks's Avatar
Are you thinkin about some chrome dubs? Yo up here in the NYC, we be straight blingin all day long!!!
Not me but this is just a phat example of how we be blingin it up!
If your gonna go with chrome it betta be 19's or better!
j/k
Old Aug 11, 2001 | 11:44 PM
brinks's Avatar
keep that chrome away from your teg, Id rather be dropped on stockers than rollin on some cheezy chrome. Be patient, if you dont like the look you will be able to get something decent soon.
Old Aug 12, 2001 | 01:02 AM
New User
Default Re: im planning on buying some used 16' chrome rims cec (brinks)
WOAH ITS MR T !!!!!
Old Aug 12, 2001 | 08:41 AM
LS-Enthusiast's Avatar
New User
Default Re: im planning on buying some used 16' chrome rims cec (Andrea_Aunie)
When you talk about improving performance through the use of aftermarket wheels and tires, it's important to figure out which aspect of your car's performance you want to improve.
* Do you want to improve acceleration?
If so, it's not really the diameter of the wheel you should worry about, but the overall diameter of the tire and the weight of the wheel/tire combo. General rule of thumb: the smaller the overall diameter of the tire, the quicker the acceleration. You can actually end up with a smaller overall tire diameter on a 16" wheel than on a 14" or 15" wheel if you pick the right size tire (205/45-16 vs. 195/55-15).
Weight is another key factor in improving acceleration, and a 20-lb wheel is just too heavy, regardless of diameter.
* Do you want to improve handling?
If handling is more important to you than acceleration, then a larger diameter wheel might be the way to go. A bigger wheel with a lower profile tire on it can definitely improve turn-in feel, as long as the tire has stiff sidewalls and good grip. But again, too much weight can counter this.
My recommendation to just about any Integra driver who wants the best of both worlds: 15" x 6.5" wheel weighing no more than 12 - 14 lbs paired with good 205/55-15 tires.
And on a more personal note, I think chrome should be left to the domestics!
Good luck!
Old Aug 12, 2001 | 09:41 AM
Prelussion's Avatar
WOAH ITS MR T !!!!!
go back to purehonda aunie!
turtlecivicsi
Honda Civic (2006 - 2015)
11
Aug 11, 2006 09:35 AM
doodooheadfart
Jan 5, 2006 02:06 PM
eas156
Nov 20, 2005 12:11 AM
anjapower
15
Aug 25, 2003 08:11 PM
2000Accord5sp
22
Oct 23, 2002 04:59 PM
