B18c1 block, Pr3 head, and CTR pistons...
on street tires, high 13s. slicks, 12s. hp... 180-200whp, depends on the tuning. i got this setup so PM me if u got any ?'s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr y0! »</TD></TR><TR><TD CLASS="quote">on street tires, high 13s. slicks, 12s. hp... 180-200whp, depends on the tuning. i got this setup so PM me if u got any ?'s</TD></TR></TABLE>
In a pipe dream. Not with a stock B16 head and not in a 96-00 coupe that hasn't been slashed to bits. Between 170-180 with good tuning. Need a good bit of weight reduciton like sub 2300lbs and some DAMN good driivng to crack a 12.9 in a "EK" coupe with under 200whp.
P.S. Bench racing's ghey.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enkeirp02 »</TD></TR><TR><TD CLASS="quote">if i added a set of toda A spec cams and went obd 1 conversion.. would that make a big difference?</TD></TR></TABLE> only if u tunned the car since then, otherwise u could be loosing power, untunned its hard to say if uve made any gain at all
thats high compression. if the cams are simple a VAFC would suffice in getitng the a/f setup alright. i would go with skunk2 stage 1 or a rocket cam if i were running that much compression. obd1 conversion wont do jack, unless u wanna run hondata. if u are thinking about hodnata convert to obd1
streetsold6teeny8
Apr 3, 2010 11:13 AM
Mentat Ghola
40
Nov 2, 2003 03:49 AM
TwistedHatch
Sep 30, 2003 06:15 PM
