92 Accord: Check Engine Code 4 & 9 Diagnosis - Test Harness?? HELP!
Old Aug 14, 2003 | 06:20 PM
hankd's Avatar
Default 92 Accord: Check Engine Code 4 & 9 Diagnosis - Test Harness?? HELP!
Previous thread...
https://honda-tech.com/zerothread?id=588941
I'm using a Helmes manual and working thru the flowcharts for those codes.
1. ECU reset
2. Start engine (will barely start and runs like ***)
3. Check Engine Light (YES)
4. Disconnect the 8P connector from the TDC / Crank / CYL sensor
5. Measure resistance between B&F (for code 4) and D&H (for code 9)
6. 260-500 ohms? (YES)
7. Check for continuity to body ground on B & F (and D & H) individually. (I did this and got no resistance from any of the 4 prongs to ground, so no continuity, correct?)
8. Reconnect the 8P connector.
9. Connect the "Test Harness" (part #07LAJ-PT3010A) only to the main wire harness, not to the ECU (Where the hell do I get this "Test harness"?????? This is where I'm stuck...
10. Measure resistance between B15 and B16
11. 260-500 ohms? Yes, check for continuity. No, repair open in blu / grn and/or blu/yel.
12. Continuity? Yes, repair short in blu/grn between ECU and distributor. No, substitue a known good EDU and recheck. If symptom goes away, replace original ECU.
So I'm at step 9...does anybody know anything about this test harness I need????
Thanks in advance,
Hank
Old Aug 15, 2003 | 02:29 AM
bill-71SS's Avatar
Default Re: 92 Accord: Check Engine Code 4 & 9 Diagnosis - Test Harness?? HELP! (hankd)
put a new dist. in it.
Old Aug 15, 2003 | 12:41 PM
hankd's Avatar
Default Re: 92 Accord: Check Engine Code 4 & 9 Diagnosis - Test Harness?? HELP! (bill-71SS)
Well, so far each step in the flow chart says that's NOT the problem and leading me towards the ECU (which I DON'T want to replace). I need to check around and see what each costs...
Thanks for the reply...
Old Aug 15, 2003 | 01:40 PM
Chiovnidca's Avatar
Is the inside of the distributor covered with brown dust?
Old Aug 18, 2003 | 10:13 AM
hankd's Avatar
Default Re: 92 Accord: Check Engine Code 4 & 9 Diagnosis - Test Harness?? HELP! (Chiovnidca)
I'm not sure...I haven't looked at it. What if it is???
Hank
Old Aug 18, 2003 | 01:33 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hankd &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure...I haven't looked at it. What if it is???
Hank</TD></TR></TABLE>
A bad bearing in the distributor housing can cause those codes. It usually accompanied by the brown dust from the bad bearing. Looking closer you will usualy see metal filings on the sensors.
Old Aug 19, 2003 | 05:38 AM
hankd's Avatar
Thanks man...I'll check that out!
Hank
Old Aug 19, 2003 | 10:18 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hankd &raquo;</TD></TR><TR><TD CLASS="quote">...
9. Connect the "Test Harness" (part #07LAJ-PT3010A) only to the main wire harness, not to the ECU (Where the hell do I get this "Test harness"?????? This is where I'm stuck...</TD></TR></TABLE>I think that test harness is a break-out box for the wiring harness that's plugged into the ECU. But they want you to plug it into the harness only, not the ECU, so you don't hit the ECU itself with your ohm-meter.
With skinny probes on your DMM you can unplug the harness & use the probes directly in B15 & B16 of the plug.
Old Aug 20, 2003 | 05:33 PM
hankd's Avatar
Thanks "JimBlake"...I'll keep that in mind...
Update...
Brown dust inside the cover...but also some oil???
Old Aug 20, 2003 | 06:00 PM
bill-71SS's Avatar
like I said before, replace it.
Old Aug 20, 2003 | 06:27 PM
hankd's Avatar
I am now ;-)
Autozone's lifetime distributor is $180...I need to see if that's the complete distributor or what though...
From Honda, just the distributor housing is $150...whole thing is about $300? from http://www.hondaautomotivepart...y.jsp
Old Aug 22, 2003 | 03:09 PM
hankd's Avatar
New destributor is on and she's running great again :-)
Thanks guys...
Hank
Old Aug 23, 2003 | 03:22 AM
Chiovnidca's Avatar
HondaNigeria
Nov 27, 2018 06:36 PM
gilligan354
Feb 8, 2009 06:43 PM
iphatcrxi
11
Jul 2, 2006 11:21 AM
rjforant
May 7, 2005 05:51 AM
NipponRacing
Jun 18, 2002 05:49 PM
