directed port nos kit on gsr(how much hp can a stock gsr handle)
i have a sportsman fogger direct port kit that i want to install on a 89 crx with a gsr swap.
i was thinging about running 125 hp
will this stock motor hanlde it?
not for long. i ran a very well tuned nitro setup(progressive nitro, and ignition controllers) , with a 75 shot on my stock 98 gsr for 6k mi. ran like a dream, and it took 1.5 seconds of my et. i can't say for a fact that 125 would kill your engine. but any increse in hp will increse the wear rate of your internals. also, stock ring lands and piston crowns wernt designd for that kind of power\combustion flame temp. altho i did get 300 whp out of my stock p\r on 12psi for 20k mi.
what i'm saying is, you never know. it all depends on the health of the motor now, and how u use the juse. but i wouldnt do it. if u do, and it works, p.m. me and **** on my face.
yes it can , but for how long is the question. fuel and timing need to be on top. better to lower it to 80 and go from there.
I spray 125 on a stock (I/H/E, Bkr7e's, 100 octane) D16y8, but I'm also pretty sure it's gonna break under 75K, and the clock is sitting on 59K now...turbo'ed GSR here I come!
i guess i should stay with 75 shot
.022 nos
.014 fuel
43psi fuel pressure (no vaccum)
900psi or higher nitrous pressure
timing 4 degrees retard from 16(12btc)
i will also use a msd window switch
i will squeeze from 3k-6500 rpm
what do u guys thinks
.022 nos
.014 fuel
ilovejdmhoes23
Feb 15, 2013 09:32 AM
oneslowsohc
Feb 16, 2005 06:48 PM
rev-speed
Mar 17, 2004 09:03 PM
