dx cluster into std.... plug and play??
Old Aug 14, 2003 | 02:53 PM
JackAcc's Avatar
Default dx cluster into std.... plug and play??
Only asking because I have heard mixed opinions on this....
I have a 91 dx gauge cluster and am installing it into my 91 std (which currently has no tach) Will it just plug right in and work? And if so...will the tach work without any wiring?
I have heard yes and no on this...just wanted to hear some other thoughts on this.
Thanks!
Old Aug 14, 2003 | 03:42 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: dx cluster into std.... plug and play?? (JackAcc)
the answer is yes, as long as the years match, I.E. 88 will not fit in 91.
stan
Old Aug 14, 2003 | 04:54 PM
haggar's Avatar
Default Re: dx cluster into std.... plug and play?? (90crxsi)
Yup. I just put an SI cluster in my STD.. 90 and 91 are the same, 88 and 89 are the same. can't put an 88/89 in a 90/91.
Old Aug 14, 2003 | 05:01 PM
JackAcc's Avatar
Default Re: dx cluster into std.... plug and play?? (haggar)
Sweet! and the tach works and all?
dankbudz11357's Avatar
how about jdm clusters? i heard those need to be rewired, would be sweet to have one in, would,t have to max out the tach at redline.
Old Aug 14, 2003 | 05:51 PM
FourthGenHatch's Avatar
Default Re: dx cluster into std.... plug and play?? (dankbudz11357)
JDM Si-R Clusters will work with the 90-91 Bezel but you need an electronic VSS for the speedometer to work.
Also I have an 88/89 Si cluster, any one need one. I want $50 + shipping for it.
Old Aug 14, 2003 | 07:49 PM
Default Re: dx cluster into std.... plug and play?? (FourthGenHatch)
JDM cluster will ONLY work with rewiring, now EDM cluster is a plug and play deal.
Yes the tach will work fine.
stan
Old Aug 15, 2003 | 05:16 PM
EG8R's Avatar
I have to move a couple wires for my JDM cluster to work.
wongburger
Dec 13, 2009 08:39 PM
+honda_monkey+
15
Jun 30, 2009 12:44 AM
91EF919
Sep 17, 2007 01:51 PM
NGUSPEED
13
Feb 18, 2005 11:55 AM
virginia_dude
Feb 6, 2002 04:47 AM
