2000 EX wiring harness on 98 CX motor
Depends on what car the motor is going in.
2000 harness will only work in a 99-00 car.
If you put the 98 Cx motor in your car, you need to either run a conversion harness or find a 99-00 cx/dx ecu.
If you run the conversion harness, you're going to get a couple codes..
it will work but you will need to modify cabin harness coz you will have an extra plug. 96-98 civics has 3 plugs as the 99-00 has 4 plugs
coupatroopa
Nov 2, 2010 06:26 PM
