sc61, 8.5:1 pistons, 750cc deka injectors...?
Old Aug 14, 2003 | 12:51 PM
NyQuiL's Avatar
Default sc61, 8.5:1 pistons, 750cc deka injectors...?
Im going to be purchasing a sc61 soon and im runnin a built engine with 8.5:1 arias pistons. Anyone know what i should be able to push with 750-780 deka injectors around possibly 14-16psi? Another question is are these injectors to big to support around 400-450whp.
Old Aug 14, 2003 | 04:43 PM
NyQuiL's Avatar
Default Re: sc61, 8.5:1 pistons, 750cc deka injectors...? (NyQuiL)
Bowmp
piggle sticklies
Old Aug 14, 2003 | 04:59 PM
AlphaKennyWun's Avatar
you mean are those injectors too small to support that kind of power? no.
if its a b18 or b16 vtec motor your probably looking at around 350 hp on pump gas at 13 psi. its was done here on a b18b with vtec head and hondata. its the same turbo i have too. i have a b18c. im putting it on the dyno next month so ill let you know.
Edit: the motor had 9:1 compression though
Old Aug 14, 2003 | 07:23 PM
TurboTegB18c's Avatar
Default Re: sc61, 8.5:1 pistons, 750cc deka injectors...? (S03Burner)
my 780cc supported 459whp at 85%duty cycle,
Old Aug 14, 2003 | 08:00 PM
NyQuiL's Avatar
what turbo was that off, thanks for the replies guys.
Old Aug 15, 2003 | 01:56 AM
Mad
yeah , those injectors will support 450 whp. i had msd 75 lbs injectors and made 500 whp with about a 95% duty cycle.
Old Aug 15, 2003 | 11:16 AM
COOKIEPUSS's Avatar
Are these a direct replacement for a B16A minus the resistor box?
Thanxs
nengx07
Jun 1, 2010 08:49 AM
sevenj
May 21, 2008 04:50 PM
LILSOWEK
Oct 18, 2006 04:08 PM
crdcz03
Aug 8, 2004 05:21 PM
Anubyss
Jan 9, 2003 09:19 AM
