bad piston rings???
Old Aug 14, 2003 | 10:53 AM
crxtreme27's Avatar
Default bad piston rings???
Just about every 2000 miles of driving my oil pressure drops dramatically, so i check the oil level and i find out that its below the lower line on the dip stick... i have checked for leaks everywhere and i still havent found any leaks... Does this mean that the piston rings are bad??? When i swapped in my DOHC ZC, i rebuilt it with all new rings, gaskets, bearings and more.. the engine has about 30k miles since the rebuilt... Should i change the piston rings?? or is there another reason why the engine is burning oil??
any help is appreciated...
thanks
Old Aug 14, 2003 | 10:55 AM
Jet Black's Avatar
Default Re: bad piston rings??? (crxtreme27)
Check your PCV valve....as b17gsr mentionned in the past...you can suck quite allot of oil through it.
Are you puffing?
Old Aug 14, 2003 | 11:46 AM
uszcrx's Avatar
is it smoking??
Old Aug 14, 2003 | 11:51 AM
silverkorn's Avatar
the only way i know of to test the rings is compression testing. doing a dry run first and then a wet, a tbsp of oil in the cylinder, and that should do it.
Old Aug 14, 2003 | 11:54 AM
Jet Black's Avatar
Default Re: (silverkorn)
Even then its total BS...I'm pissing oil out of my rings and I have perfect compression........its ghey....leakdown is a bit more accurate.
Old Aug 14, 2003 | 12:07 PM
crxtreme27's Avatar
Default Re: bad piston rings??? (uszcrx)
I dont really see any smoke coming out... i guess ill do a compression and leak test too..
thanks
any more info??
Old Aug 14, 2003 | 12:27 PM
Malgerus's Avatar
try dumping a bit of oil in the cylinder to see if that bumps compression up dramatically. If it does, it's rings. Leak down test will tell you if you have a blown headgasket or leaking valve seals.
Old Aug 14, 2003 | 01:21 PM
Outsane's Avatar
a leak down test will only test your compression rings..
If you buring oil and you think its your rings it would be your oil rings.
Or it could be your Valve stem seals.
Or your PCV
Old Aug 26, 2003 | 01:25 PM
B_1_8_hatch's Avatar
what if there's oil on your plugs, does that necessarily mean its your rings? could it be bad spark plug gasket deals?
i don't have smoke, my compression is fine, i'm not losing oil, but i found some oil
on my plugs..hmmmmm any ideas?
benjoh
Oct 30, 2017 02:08 PM
FireInTheHead
Nov 4, 2014 04:15 PM
drudy
Sep 22, 2005 01:42 PM
_Endless_
Jun 14, 2003 08:02 AM
tominos
22
Feb 18, 2003 08:55 PM
