rear washer trick...
Old Aug 14, 2003 | 09:41 AM
civickidd99's Avatar
Default rear washer trick...
Hey I just tried the rear camber washer trick last night and it helped out in the toe area ALOT. So, if you're thinking that the trick is just bull sh*t, then think again. Thanks alot to whoever thought up this cheap fix!
Old Aug 14, 2003 | 09:42 AM
Spade's Avatar
Default Re: rear washer trick... (civickidd99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickidd99 &raquo;</TD></TR><TR><TD CLASS="quote">Hey I just tried the rear camber washer trick last night and it helped out in the toe area ALOT. So, if you're thinking that the trick is just bull sh*t, then think again. Thanks alot to whoever thought up this cheap fix!</TD></TR></TABLE>
Never said it was bullshit, just said it wasn't the safest way to do it.
Old Aug 14, 2003 | 09:44 AM
Default Re: rear washer trick... (Spade)
what isn't safe about it, the thread depth? I only used about a 1/8 of an inch worth of washers.
Old Aug 14, 2003 | 09:48 AM
Spade's Avatar
The possibilty of using "less than high grade" metal.
Stress issues.
Old Aug 14, 2003 | 09:49 AM
wilsel's Avatar
Don't you mean it helped w/ the negative camber? Or are you talking about something else?
Old Aug 14, 2003 | 09:55 AM
EK MONEY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">The possibilty of using "less than high grade" metal.
Stress issues.</TD></TR></TABLE>
also, the contact patch of the control arm to the body is now less.
bimmeris
Jul 14, 2008 10:28 PM
vtechphone
Jun 10, 2005 09:18 PM
EK k kay
Suspension & Brakes
May 17, 2005 09:39 AM
honda41
Dec 30, 2003 01:08 AM
Henry HA
19
Jun 5, 2003 01:09 PM
