96 Accord LX CEL code 90
Old Aug 14, 2003 | 09:11 AM
Shft@9GSR's Avatar
Default 96 Accord LX CEL code 90
It's not the gas cap. I was also told it was the "check valve" (honda pulled the exact code). I was told that it is around the evap canister.
My question is... According to the honda parts catalog, the only valves they show are for EGR. And it's just called Valve 1 and Valve 2 pretty much.
It's my girlfriends car and she doesn't want to pay honda $250 for parts/labor.
Are these even the valves I need? Do both need to be replaced?
Thanks in advance
Old Aug 14, 2003 | 02:39 PM
bill-71SS's Avatar
Default Re: 96 Accord LX CEL code 90 (Shft@9GSR)
your emission controls on a 96 are under warranty for 15yrs or 150,000mi. If you fall in this catagory, go back to the dealer
Old Aug 14, 2003 | 07:48 PM
AngryTroll's Avatar
Default Re: 96 Accord LX CEL code 90 (bill-71SS)
It's amazing how many Honda owners don't know about the 150,000 mile warranty. It makes me wonder if Honda ever notified their customer's about the extended warranty or if the customer's had to figure it out on their own.
Modified by AngryTroll at 1:03 AM 8/16/2003
Old Aug 15, 2003 | 09:06 AM
Shft@9GSR's Avatar
Default Re: 96 Accord LX CEL code 90 (AngryTroll)
no ****!! it's my girlfriends car, and I know I didn't know about it, so that means she definately didn't know about it.
Sad part is... I think her car has more than 150K miles
Thanks for the information.
Old Aug 15, 2003 | 03:07 PM
AngryTR0LL's Avatar
You have a P1456 (evap leak). A loose cap can set this code. It doesn't matter if it's not loose now. The light will not turn off by itself (well...eventually it will but it takes awhile). Do you have the correct fuel cap? Did you have it tested?
There's a few different valves related to the EVAP system. The 2 way valve and the purge solenoid come to mind. Some of the later Accords also come with a bypass solenoid and a vent shut valve but I honestly don't remember if the '96 came with those valves.
All you need to do is find which one is leaking. The problem is, just because you have a p1456 doesn't automatically mean you have a leaking valve. You cold have a leaking hose, canister, tank seal, etc.
Sandra Wilson
Mar 15, 2018 12:39 PM
Jacqueline
Jan 4, 2017 07:58 AM
blaze the chemi
Dec 8, 2006 04:08 PM
KNCRSR5R
Aug 20, 2004 04:55 PM
