JDM B18C5 WITH WHAT ECU?
Old Aug 14, 2003 | 08:48 AM
APEX CRX's Avatar
Default JDM B18C5 WITH WHAT ECU?
OK HERES THE DEALEO, I WANT TO SWAP A 95 JDM B18C5 OBD 1 INTO MY 89 CRX, I WANT TO KNOW IF ANYONE KNOWS DO I HAVE TO RUN A 98+ USDM ECU TO MATCH THE MOTOR AND CONVERT TO OBD 2 OR WOULD ANY USDM ECU WITH OBD 1 TO MATCH THE ENGINE WORK? LIKE A P28?
Old Aug 14, 2003 | 10:43 AM
APEX CRX's Avatar
BUMP
Old Aug 14, 2003 | 10:46 AM
.ShawnD.'s Avatar
chiped p28 i hear works well
Old Aug 14, 2003 | 10:50 AM
APEX CRX's Avatar
Default Re: (.:s h a w n D:.)
YEAH I HEARD THAT TOO BUT I'M TRYING TO FIGURE IF IT WOULD BE SMOG LEGAL HERE IN CALI? ANYONE IN CALI KNOW THIS?
Old Aug 14, 2003 | 01:16 PM
RexB16's Avatar
Default Re: (APEX CRX)
no motor swap is smog legal in cali.
Old Aug 14, 2003 | 01:38 PM
APEX CRX's Avatar
Default Re: (RexB16)
WHAT DO YOU MEAN BY THAT?
Old Aug 14, 2003 | 04:55 PM
EG8R's Avatar
Take the friggin caps lock off.
Old Aug 14, 2003 | 04:58 PM
dankbudz11357's Avatar
Default Re: (skelly ed6)
read the sent to smog ref thread. wondering what i'm gonna do when i have to get a smog check.
Old Aug 15, 2003 | 12:06 AM
HandCommand's Avatar
Default Re: JDM B18C5 WITH WHAT ECU? (APEX CRX)
The JDM B18c with PR3 head is the same as what we call the B18c5. Well, actually, Id rather opt for the JDM R motor with a higher comp. ratio.
Anyways, those motors come with the JDM P73 ecu. The ones I got recently purchased had JDM ecu's that didnt even look for the VTEC Oil Pressure (Code 22). They were OBD2 ecu's.
Personally, I run either a chipped P28 or better yet a P28 with Hondata.
Old Aug 15, 2003 | 03:39 AM
markleavey's Avatar
Default Re: JDM B18C5 WITH WHAT ECU? (HandCommand)
P28 with Hondata. Thats what I will be using on mine. Will probably just start with chipped p28 until I can afford the Hondata system though.
Mark
Old Aug 15, 2003 | 04:27 AM
Fred n J_v2.0's Avatar
can a obd0 pr3 ecu run the type R motor?
Old Aug 15, 2003 | 06:24 AM
1_bad_EF's Avatar
Default Re: (95VXFRANK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95VXFRANK &raquo;</TD></TR><TR><TD CLASS="quote">can a obd0 pr3 ecu run the type R motor?</TD></TR></TABLE>
yes use a obd0 b16a distributor. you have to put the b16a wiring harness on the R. switching plugs when necessary.
trequartista_10
Oct 22, 2012 09:53 PM
djviet2000
Mar 3, 2008 10:47 PM
civicsi940
Jan 24, 2005 04:48 AM
Mr.E.G.
Dec 29, 2004 09:32 AM
smkngsr
Jun 9, 2004 01:36 PM
