help! trouble removing my oil pan!
94 d16z6, civic ex
ok so i am removing my oil pan in order to change a rod bearing and a main bearing, but i can't get the pan off! i have the hedder off and most of the bolts but there are two that are wedged in against the tranny that seem impossiable to get at. they are in a corner and i can't fit a socket on it and i can't get a wrench to it, how can i get it off?can i take that cover off thats separting the tranny from the oil pan? i need to remove two bolts then but it looks like my tranny fluid will pour out if i remove them. if anyone can give me some advice on how to drop the pan i would really appriciate it!
you need to take your fywheel cover plate off. That is the only way to get to those bolts. There is either two or three bolts holding that plate on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">you need to take your fywheel cover plate off. That is the only way to get to those bolts. There is either two or three bolts holding that plate on.</TD></TR></TABLE>
copperfox
Jul 15, 2005 09:42 PM
