Trying to learn about trannies and have a question.
Old Aug 13, 2003 | 10:27 PM
1999all_motoR_teg's Avatar
Default Trying to learn about trannies and have a question.
Now I've read and read and searched and search and I've learned quite a bit about trannies.
I've looked over this site http://www.allmotorhonda.com/t...s.htm and see all the gear ratios and I have a question.
Let's take a 1999 GS-R tranny and a 1999 LS tranny and if you look at the gearing the 1st and 2nd gears are EXACTLY the same but the final drive is different.
Now my question is ARE the GS-R and LS trannies 1st and 2nd gears identical or does the final drive make a difference?
Like let's say they were both mounted to a GS-R engine. Would the LS tranny on a GS-R engines 1st and second gear pull exactly the same as a GS-R's 1st and 2nd gear on a GS-R engine? or because of the final drive would it pull different??
I know that the GS-R tranny would pull harder in 3rd, 4th and 5th cause the gearing is shorter but would 1st and 2nd pull identically??
Thanks in advance and sorry for the long drawn out question.
Old Aug 13, 2003 | 10:39 PM
Default Re: Trying to learn about trannies and have a question. (CIVIC2)
up
Old Aug 13, 2003 | 10:57 PM
TTT
Old Aug 14, 2003 | 12:56 AM
CivicNA's Avatar
yes if 1st and 2nd ratio is the same
63Bmechanic
Aug 26, 2010 06:53 PM
jdm_gsr
Feb 11, 2004 05:55 AM
Lightning Orders
Jan 3, 2004 08:12 AM
1999all_motoR_teg
Aug 14, 2003 10:01 AM
1999all_motoR_teg
Aug 14, 2003 12:45 AM
