2001 type r motor in a 91 HF CRX
Old Aug 13, 2003 | 08:58 PM
JDM JOE's Avatar
Default 2001 type r motor in a 91 HF CRX
Guys I need a lot of help... I want to put a type r motor in my crx. Can someone please give me a detailed guide that I can follow as far as what i need for the swap as well as how it is to be done. I also would like suggestions on some additional parts that have to be purchased and how the wiring is set up...thanks in advance for all your help
Old Aug 13, 2003 | 11:14 PM
crex23's Avatar
Default Re: 2001 type r motor in a 91 HF CRX (JDM JOE)
I don't usually say this, but do a search on the topic. It has been covered numerous times, I think the most recent was about 2 months ago.
Old Aug 14, 2003 | 05:03 AM
Dancing is Forbidden's Avatar
Default Re: 2001 type r motor in a 91 HF CRX (crex23)
YOU NEED:
Hasport mounts
Hasort Shift linkage
Hasport's new cable to hydro conversion kit (might still be in the works but I know they have it)
OR
you could get a new pedal assembly and get a slave cylinder
And here is where it gets tricky:
You can either run it OBD-0
or OBD-1 or OBD-2
If you do it the latter of the two you will need to get a shock tower harness and run that to the ecu, and if you go OBD-1 get a jumper
If you want OBD-0 get a B16a dizzy. OBD-0 Injectors and then the hasport jumper kit for vtec. Should be as easy as that.
88crxdxfastwhip
Mar 8, 2006 10:22 AM
JDM JOE
Aug 14, 2003 08:28 AM
CRX A4
Feb 18, 2003 07:25 AM
rOby
Oct 19, 2002 05:59 PM
b16powwer
Aug 14, 2002 10:58 PM
