Handling problems after installing SPC rear lower control arms...
Old Aug 13, 2003 | 08:28 PM
AThiker's Avatar
Default Handling problems after installing SPC rear lower control arms...
I have a 93 hatch with Eibach Pro-kit springs and KYB AGX shocks... Today I installed SPC rear lower control arms and after I put my car back on the ground and retightened everything the cars rear wheels went from sitting a little, but only a little like this... /====\ to sitting a lot like this... \====/ I liked the way it handled ALOT better before, now it sucks and the car feels heavy and like it is going to tip. So I untightened and re-adjusted everything and it still does it. What can I do to fix this? Could simpy changing rear LCA's throw my alignment off this much? It just doesn't seem right. Any help is greatly appreciated.
Old Aug 13, 2003 | 08:39 PM
Casey's Avatar
Default Re: Handling problems after installing SPC rear lower control arms... (jgop_151)
maybe a dumb question, and dont take offense, but did you put them on upside down/backwards?
Old Aug 13, 2003 | 09:05 PM
92 civic VX B18c's Avatar
HT Black Ops
Wow, that sucks, I can't help but wonder if your LCA's got mixxed up from the place you orderd them from, they should fit just like your stock ones. They shouldn't affect your camber that much..
Old Aug 13, 2003 | 09:46 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Handling problems after installing SPC rear lower control arms... (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">maybe a dumb question, and dont take offense, but did you put them on upside down/backwards?</TD></TR></TABLE>
What he said. Sounds like they're in back'erds.
Old Aug 13, 2003 | 10:24 PM
NNHC's Avatar
Check if you got the EK one as well if you installed them correctly. It should be a direct replacement part.
Old Aug 14, 2003 | 05:46 AM
AThiker's Avatar
Default Re: Handling problems after installing SPC rear lower control arms... (NNHC)
I didn't install them upside down, I had read a topic about someone doing that, so I made sure not to. This is how I installed them...
How do I tell the difference between the EK and EG ones? Maybe I did get the wrong ones
Old Aug 14, 2003 | 05:56 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
EG ones are thicker then the EK ones.
Also not every LCA is designed the same, an actual pic of LCA's on your car would help. That pic looks like the correct way for SRR's.
Old Aug 14, 2003 | 05:57 AM
Mike_C's Avatar
i'm gonna vote for the ever popular: backwards/upside down
Old Aug 14, 2003 | 06:59 AM
AThiker's Avatar
Default Re: (JMU1337)
I have the blue ones in the middle (except mine are red) The ones with the endlink mounting hole on the top rather than in the middle ...
I think those are the EG ones?
I will take pics of them installed on my car. Thanks for everyones help.
BTW: Both those pics are from SPC's site... http://www.spcperformance.com/....html
Old Aug 14, 2003 | 07:21 AM
SloCivicHMM's Avatar
Default Re: (jgop_151)
I believe these lower control arms are designed to allow a bigger wheel/tire combo and "correct" camber inwards....just go get an alignment......I'm asumming its just slightly \\\ not undrivable correct??? You should be fine.....
-Jose
Old Aug 14, 2003 | 07:32 AM
JaeOne3345's Avatar
Default Re:
SPC arms change the oem geometry slightly, i believe it effects track width and camber. and if they mess with camber, they are gonna mess with toe as well.
Old Aug 14, 2003 | 08:28 AM
AThiker's Avatar
Default Re: Re: (JaeOne3345)
It is drivable but noticably different. It feels like a bad case of understeer. When I go get an alignment will they be able to correct it that much?
Old Aug 5, 2004 | 01:33 PM
93Civic_hb's Avatar
Default Re: Re: (jgop_151)
It is true that they are designed to be used with a wider tier/wheel combination. Due to the control arm being designed .5" shorter than the OEM specs. I have them currently and been experiencing the same ride conditions as you do.
Old Aug 5, 2004 | 01:59 PM
n1div's Avatar
Old Aug 5, 2004 | 02:28 PM
NSR500's Avatar
The SPC LCA's are supposed to be used in conjunction with the SPC Upper Rear Camber Adjusters. That is what is causing your Camber problems. I suggest you put your stock LCA's back on and order the SPC Upper Adjusters. Driving around like that is extremely unsafe.
Old Aug 5, 2004 | 02:34 PM
Sliced Beard's Avatar
Default Re: Handling problems after installing SPC rear lower control arms... (NSR500)
unless you like to drift a FF car
Farlander
Mar 2, 2011 05:13 PM
raymond4486
10
Apr 18, 2009 08:58 AM
RED_90TEG
Suspension & Brakes
26
May 20, 2008 01:41 AM
slammed95lude
Apr 12, 2007 05:52 PM
ESCALVANTE
11
Mar 12, 2002 06:17 PM
