Block Guard for all motor?
Old Aug 13, 2003 | 08:12 PM
Luserkid's Avatar
Default Block Guard for all motor?
Im going to go all motor with my B18c. I heard from a mechanic that honda motors wallbel like a bitch and thats why rods go thru the block. He said i should get a blockguard to prevent that. But also his a Toyota freak. So i have to ask. Block guard or no block guard. Im planning on a 11.6:1 compression in the end, so is it worth it? Thanks
Old Aug 13, 2003 | 08:44 PM
EF_LSVtec's Avatar
Default Re: Block Guard for all motor? (Luserkid)
You dont need it...especially on a B18C (thought it came w/ it already)..just make sure you get everything balanced and blueprinted. I would invest on eagle rods too in case you decide to rev your motor pass 9.5K regularly and of course, ARP bolts all the way.
Old Aug 13, 2003 | 11:30 PM
allmtr's Avatar
Default Re: Block Guard for all motor? (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">You dont need it...especially on a B18C (thought it came w/ it already)..just make sure you get everything balanced and blueprinted. I would invest on eagle rods too in case you decide to rev your motor pass 9.5K regularly and of course, ARP bolts all the way.</TD></TR></TABLE>
exactly. no need for a block guard with a streetable allmotor setup...
Old Aug 14, 2003 | 08:25 AM
JDMHN8's Avatar
Are you talking about a block guard that goes around the upper part of the cylinder sleeves or a the maind cap girdle? The B18C (and any B-series, for that matter) did not come with a "block guard". The B18C did, however, come with a 3 main bearing cap girdle. But, I will also say that a block guard is unecessary, especially if you were to install it improperly (not following up with a bore and hone).
ARP rod bolts are always a good idea...
Old Aug 14, 2003 | 08:31 AM
advanracing62's Avatar
Default Re: Block Guard for all motor? (JDMDA9)
it has always been my understanding that the BG was for boosted applications.
HondaAddict91
Oct 5, 2016 10:57 PM
terronb20ek
Mar 15, 2011 02:50 PM
jasnjdm
Feb 3, 2008 12:52 PM
pip9
Nov 16, 2003 11:39 AM
