Boosting B18c5... - what goes out first?
Old Aug 13, 2003 | 07:01 PM
vtec.dc2's Avatar
Default Boosting B18c5... - what goes out first?
At 70K miles (2k of mild boost), my headgasket is leaking.. So i have to replace that.. at least..
I want to run 275whp. i have all the proper fuel parts along with hondata.. I'd liek to stick with oem parts if i can.. Its 120whp more stress on the engine than stock setup..
So how much stress can stock engine handle and what parts would go/brake/leak first?
Old Aug 13, 2003 | 07:18 PM
CRVRX's Avatar
Default Re: Boosting B18c5... - what goes out first? (vtec.dc2)
I have supercharged and turbo charged many type Rs. Scooter ( on this board) had his stock Type R block boosted for about one yaer before we built him a new motor. He was making around 280WHP at around 10psi.The block was fine when it came out, I looked it over and I was impressed with how clean everything looked.
i would say the first thing to go are the piston ring lands , around the intake valve relief. The key is not to detonate it , go easy on the timming and keep it around 12-1 A/F and you should be fine .
Old Aug 13, 2003 | 07:22 PM
vtec.dc2's Avatar
Default Re: Boosting B18c5... - what goes out first? (CRVRX)
what usually goes after piston ring lands.. or is that good enough for 275-280whp?
Old Aug 13, 2003 | 07:34 PM
CRVRX's Avatar
At 280 -300 WHP tuned right I think you will be fine. The only things I have seen break are the ring lands. I don't think I would go much 300 with out lowering the compression and beef up the rods.
Old Aug 13, 2003 | 07:37 PM
vtec.dc2's Avatar
thanks.. hopefully the only damage right now is headgasket once i take everythign apart..
ScottEK's Avatar
When the "ringlands" go what all has to be replaced?
Old Aug 14, 2003 | 11:23 AM
vtec.dc2's Avatar
Default Re: Boosting B18c5... - what goes out first? (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">When the "ringlands" go what all has to be replaced?</TD></TR></TABLE>
i'd like to know that too..
Old Aug 14, 2003 | 11:27 AM
Benbuilt4u's Avatar
my type-r makes 310 whp at 8100 rpm (hondata revlimiter was set to low) stock motor with headspacer and hondata s100 w/ boost option.
Old Aug 14, 2003 | 11:38 AM
01ITR#700's Avatar
Default Re: Boosting B18c5... - what goes out first? (Benbuilt4u)
Ringlands love to go, mine did eventually
Mark
Old Aug 14, 2003 | 11:51 AM
DC2R714's Avatar
Default Re: Boosting B18c5... - what goes out first? (01ITR#700)
Ya tune conservatively if you are going to run 10psi. This is what happens when you lean out and detonate.
Ringlands go, then rings, then piston, then sleeves (NOT neccessarily in that order)
Old Aug 14, 2003 | 11:53 AM
AlLMoToRvOtEr's Avatar
Ya I agree with the ringlands, but if you have it properly tuned then you should be alright for a decent amount of time. Just make sure that you have everything just right and that it's not detonating cuase that will break the ringlands or just break the piston and that would be bad.
Old Aug 14, 2003 | 01:22 PM
redlinegsr's Avatar
Default Re: Boosting B18c5... - what goes out first? (turboDC2)
I agree....ringlands...yet have you addressed the problem of why your headgasket is leaking? Are you running stock head bolts? If so I recommend switching to ARP to prevent head lifting under high boost
Old Aug 14, 2003 | 02:16 PM
93LSivic's Avatar
Default Re: Boosting B18c5... - what goes out first? (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Ya tune conservatively if you are going to run 10psi. This is what happens when you lean out and detonate.
Ringlands go, then rings, then piston, then sleeves (NOT neccessarily in that order) </TD></TR></TABLE>
No, thats what happens when you take your car for tuning at SKR in NJ.
Old Aug 14, 2003 | 02:49 PM
vtec.dc2's Avatar
Default Re: Boosting B18c5... - what goes out first? (redlinegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr &raquo;</TD></TR><TR><TD CLASS="quote">I agree....ringlands...yet have you addressed the problem of why your headgasket is leaking? Are you running stock head bolts? If so I recommend switching to ARP to prevent head lifting under high boost</TD></TR></TABLE>
i'm not sure why my headgasket is leaking.. motor never been opened.. i'm probablyg going to use stronger head bolts.. arp or whatever is good..
Old Aug 14, 2003 | 03:24 PM
PM-Performance's Avatar
i beat the **** outta nice at 11psi the car ran great , i took it apaprt and oufnd out i had cracked ring lands, it wasnt a big deal that it broke, but i will agree the pistons are defff the weak spot from all the stuff i have seen .
Old Aug 14, 2003 | 03:32 PM
hulkhb's Avatar
Default Re: Boosting B18c5... - what goes out first? (itr206)
itr206 thats the man.....my inspiration for me boosting my C5
Old Aug 14, 2003 | 03:49 PM
Default Re: Boosting B18c5... - what goes out first? (hulkhb)
hahahaah thanks hulk . i need some inspiration myself lately. that deff helps
Old Aug 14, 2003 | 04:35 PM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">what usually goes after piston ring lands.. or is that good enough for 275-280whp?</TD></TR></TABLE>
...At 280hp...it would only be a matter of moment for the rings to go...if not the ring the whole damn piston.
then headgasket
then clutch
anymore than 280, your looking to blow sleeves (if untuned)
mfisher1987
Jun 25, 2012 05:56 PM
Prudz_lude
Mar 17, 2009 03:33 PM
ScootinIntegra
Feb 7, 2004 05:31 PM
ChaosUnbound
Jan 14, 2004 05:33 PM
xerox445
Dec 14, 2003 07:42 AM
