VFAC and NOS... Fast times or Hard times??!
Old Aug 11, 2001 | 12:17 PM
VTEC Girl's Avatar
New User
Default VFAC and NOS... Fast times or Hard times??!
Going with a final setup decision of header/exhaust/intake/VTEC AFC/and NOS. Will I be able to spank an Integra then??
Old Aug 11, 2001 | 12:36 PM
Jared's Avatar
Default Re: VFAC and NOS... Fast times or Hard times??! (F22_NA)
wet or dry nos system?
Old Aug 11, 2001 | 08:23 PM
VTEC Girl's Avatar
New User
Default Re: VFAC and NOS... Fast times or Hard times??! (Jared)
whats the difference
Old Aug 12, 2001 | 06:07 AM
sohc_boy's Avatar
wet system - adds fuel and nitrous
dry system - adds nitrous only
Old Aug 12, 2001 | 10:53 AM
AllMotorITR's Avatar
New User
Default Re: VFAC and NOS... Fast times or Hard times??! (sohc_boy)
I have an ITR, and I was wondering if bolt-ons and nitrous would work well too... I was considering a 75 shot Zex Dry shot... Would wet be better?
Old Aug 12, 2001 | 01:10 PM
GSpeedR's Avatar
Default Re: VFAC and NOS... Fast times or Hard times??! (PYTypeR408)
Direct-port would be better, but a tad bit more expensive.
Old Aug 12, 2001 | 03:21 PM
VTEC Girl's Avatar
New User
Default Re: VFAC and NOS... Fast times or Hard times??! (GSpeedR)
how much is a direct port job
Old Aug 12, 2001 | 03:26 PM
SOHCArchangel's Avatar
yo man, i have a vafc in my car and plain ol tegs with i/h/e and nothing else i had fun spanking,
Old Aug 12, 2001 | 04:25 PM
BRacing's Avatar
New User
Default Re: VFAC and NOS... Fast times or Hard times??! (SOHCkordVTEC)
For a direct port setup, and to pay to have it ALL done for you, would cost about $2000. This should include most of the parts and labor.
Figure at least
$600 for the kit
$900 for labor
plus misc parts and the like.
To do the direct port setup, you'll need to remove the intake manifold and drill and tap a hole into each runner. Then plumb a nozzle into each one. When done correctly, they look really good, and work good too. I've added about 400HP with a direct injection kit (it was on a BBC).
You can even get tricky and put the ports on the underside of the manifold to hide the injection system. If you're adding more than 50hp, you should get a new/additional fuel pump, as well as a replacement long block so when you blow up the engine....
el arbi
Dec 2, 2002 01:05 PM
civicmark
Jul 7, 2002 08:20 PM
hobo79
Feb 1, 2002 10:46 PM
Hondasaurs
Dec 1, 2001 08:25 PM
