b16a throttle body
Old Aug 13, 2003 | 02:11 PM
blk-widow's Avatar
Default b16a throttle body
I have a 90 b16a in a 93 civic, the problem is it sits and revs to 1500 then down to 1000. I have a 95 LS throttle body on it and I think that could be the problem. NEED HELP
Old Aug 13, 2003 | 02:12 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: b16a throttle body (blk-widow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk-widow &raquo;</TD></TR><TR><TD CLASS="quote">... the problem is it sits a revs. ...</TD></TR></TABLE>
what is the problem? proof read before you post
Old Aug 13, 2003 | 02:22 PM
blk-widow's Avatar
ANY ONE???
Old Aug 13, 2003 | 02:23 PM
GDM Z28's Avatar
Default Re: b16a throttle body (ninjaMONKEY)
does it go back and forth from 1500 to 1000 like a surge? if so check your IAC sensor. are you getting a check engine light? or if it starts idleing at 1500 and when it warms up it drops to 1000 thats fine. we need more details man.
Old Aug 13, 2003 | 02:24 PM
Nextelbuddy's Avatar
Default Re: (blk-widow)
on the first gen b16a motors there are a bunch of vacuum lines on the back of the intake manifold. u need to check each one and see if u have a vacuum leak. also check your IACV on teh back of the intake mani as well then play with the idle ait adjustment screw on teh throttle body which ever u decide to use
Old Aug 13, 2003 | 02:29 PM
blk-widow's Avatar
Default Re: (nextelbuddy)
I alread replaced the iacv, tried the screw, change my fit valve. could a LS throttle body cause the problem?
Old Aug 13, 2003 | 02:34 PM
check your vacuum hoses theirs like 3 or 4 on the first gen intake mani that aren not on 2nd gen motors. almost anyone that uses 1st gen b16 alwasy has idle surges cuz they dont get the vacuum hoses connected right.
Old Aug 13, 2003 | 02:36 PM
blk-widow's Avatar
there are no leaks but I'm not sure where they all go I have only one pluged.
Old Aug 13, 2003 | 02:41 PM
blk-widow's Avatar
BUMP
Old Aug 13, 2003 | 03:10 PM
blk-widow's Avatar
[img]C:\My Documents\eBay Motors item 2418494230 (Ends Jun-13-03 112824 PDT ) - HONDA TRX 400EX ATV Racer Aluminum Nerf Bars_files\DSCF0011.JPG[/img]
Old Aug 13, 2003 | 03:12 PM
blk-widow's Avatar
[img]C:\My Documents\eBay Motors item 2418494230 (Ends Jun-13-03 112824 PDT ) - HONDA TRX 400EX ATV Racer Aluminum Nerf Bars_files\DSCF0006.JPG[/img]
Old Aug 13, 2003 | 03:33 PM
IDriveHonda's Avatar
I think it si your throttle body gasket causing a vaccum leak. Try taking the T/B off and putting the sealant of your choice on it and then see what happens. It is a cheap fix too.
Old Aug 13, 2003 | 03:57 PM
blk-widow's Avatar
Default Re: b16a throttle body (IDriveHonda)
I made my own gasket And have checked for leaks. What is the vacum hose routing?
Old Aug 13, 2003 | 04:04 PM
ninjaMONKEY
Guest
Posts: n/a
you can also try cleaning out the throttle body and intake manifold. make sure that vaccum lines that aren't ran are plugged off. also i dont know how well a home-made gasket would work. I would get one from honda. Also if you clean everything and get all the vacum lines hooked up right and still have problems, its time to get a b16 TB.
Old Aug 13, 2003 | 04:32 PM
dantastic's Avatar
yea... my b16 sir1 idles at around 1200, and surges sometimes. i have a b16a2 manifold that im gonnna put on later (just too lazy to put it on)
Old Aug 15, 2003 | 02:13 PM
GDM Z28's Avatar
Default Re: (dantastic)
check your TPS as well.....
Old Aug 15, 2003 | 04:47 PM
bushfreakz's Avatar
pcv hose? that would make real jumpy idle constantly
Old Aug 16, 2003 | 05:26 AM
Xsi's Avatar
Xsi
Did you set your TPS properly? definately check that
handa
19
May 24, 2005 03:43 AM
90crxsijc
Apr 12, 2005 11:32 AM
TheHatchHog
Apr 23, 2004 03:08 PM
blk-widow
Jul 16, 2003 08:23 AM
Don
Apr 29, 2001 08:43 PM
