dohc zc tranny?
Old Aug 13, 2003 | 01:40 PM
crx88fast's Avatar
Default dohc zc tranny?
will a dohc zc tranny fit on my sohc zc? cause i found one for cheap but i dont know if it will fit
Old Aug 13, 2003 | 03:41 PM
CRXRageD's Avatar
Default Re: dohc zc tranny? (crx88fast)
Yes but you will have to compensate for the axles.
Old Aug 14, 2003 | 11:06 PM
crx88fast's Avatar
Default Re: dohc zc tranny? (CRXRageD)
are the gear ratios pretty good in the zc trannys? when you say compensate do you mean get new ones? could i get the axles here in the us? and is it a direct fit?
crx88fast's Avatar
oh yeh and what about clutch... would i have to get a new one also?
Old Aug 14, 2003 | 11:26 PM
jdm169's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx88fast &raquo;</TD></TR><TR><TD CLASS="quote">are the gear ratios pretty good in the zc trannys? when you say compensate do you mean get new ones? could i get the axles here in the us? and is it a direct fit?</TD></TR></TABLE>
you will need an intermediate shaft and i think some 90-93 teg axles, someone correct me if i'm wrong, and it depends what you mean by good for the gear ratios, the tranny is not good for gas mileage, the gears are shorter ( if that's how you say it?) meaning you get through the gears quicker
Old Aug 14, 2003 | 11:28 PM
jdm169's Avatar
nevermind..., bump
Old Aug 15, 2003 | 06:35 AM
davens's Avatar
Stock to stock, the Si and ZC trannys perform nearly the same.
The Si has a good gear ratio and great final drive
The ZC has a great gear ratio and good final drive
...making them about equal.
However, if you take what's great about both of them and put them together, it makes one fast tranny. The ZC 1-4 gears, the Si 5th gear and the Si final drive can even be put in the Si case, eliminating the need for a ZC intermediate shaft and use of your original Si axles.
So how fast? I would say moving from an Si to a hybrid has a similar increase experienced when switching from DX to Si. Definately makes more of an impression on the *** dyno than I/H/E.
I've got a couple stock ZC trannys and I have a guy that can build hybrid setups...let me know if you're interested.
Old Aug 15, 2003 | 08:22 AM
jdm169's Avatar
Default Re: dohc zc tranny? (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">I've got a couple stock ZC trannys and I have a guy that can build hybrid setups...let me know if you're interested.</TD></TR></TABLE>
out of curiousity how much would your friend charge if i provided him with both trannies? and where are you located? thanks
Old Aug 15, 2003 | 09:49 AM
crx88fast's Avatar
hey yeh im interested.... how much to have one built... or buy on of your stock zc trannies? i need one reallybad!!!
Old Aug 15, 2003 | 11:44 AM
blah13's Avatar
Word, post prices for those ZC trannys.
Old Aug 15, 2003 | 12:37 PM
DJ_SaNdOz's Avatar
Default Re: dohc zc tranny? (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">Word, post prices for those ZC trannys. </TD></TR></TABLE>
werd
Old Aug 15, 2003 | 12:41 PM
davens's Avatar
Default Re: dohc zc tranny? (DJ_SaNdOz)
check my classifieds ad
Modified by davens at 4:42 PM 8/15/2003
Old Aug 16, 2003 | 12:38 PM
crx88fast's Avatar
i couldnt find your classified ad... how much do you want for the trannies or can you give me a link?
Old Aug 16, 2003 | 01:16 PM
davens's Avatar
https://honda-tech.com/zerothread?id=593208
Old Aug 16, 2003 | 03:27 PM
LoneStarCRX's Avatar
Davens is a straight-up guy, too. Did my swap and will be doing my tranny soon. Good man.
teal91
Nov 26, 2008 07:44 AM
Jt'sRex
May 2, 2008 04:02 PM
Sherm
Jan 12, 2004 06:16 PM
spun Vtec
Jan 15, 2003 11:23 AM
OldSchoolCrxSiR
14
Jul 30, 2002 11:14 PM
