CTR pistons in ITR
Old Aug 13, 2003 | 11:21 AM
KRiS1's Avatar
Default CTR pistons in ITR
What compression would .25 over CTR pistons make in a B18c5 block with the ITR head milled .15?
Old Aug 13, 2003 | 11:27 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: CTR pistons in ITR (POS Hatchback)
Compression ratio: Volume of the cylinder, piston dish and head dish and
headgasket from top to bottom of the stroke, divided by the head, piston,
and headgasket volume or:
bore(in.) x bore(in.) =__ x .7854 =__ x stroke (in.) =__/ .061=__cc of
cylinder + (head cc +piston cc + headgasket cc) / (head cc+ piston
cc+headgasket cc) = compression ratio
do the math
Old Aug 13, 2003 | 12:25 PM
KRiS1's Avatar
Default Re: CTR pistons in ITR (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">
do the math
God Damn
I knew thier would be math involved.
Anyone want to take a stab?
Old Aug 13, 2003 | 12:33 PM
soakit's Avatar
little over 12-1
Old Aug 13, 2003 | 12:34 PM
Casey's Avatar
Default Re: CTR pistons in ITR (soakit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soakit &raquo;</TD></TR><TR><TD CLASS="quote">little over 12-1</TD></TR></TABLE>
wrong, more like 12.5-12.9
Old Aug 13, 2003 | 12:57 PM
advanracing62's Avatar
Default Re: CTR pistons in ITR (Casey)
I'll say about 12.65-13.1:1. Normal setup would be about 12.1-12.3:1 with head milling it will put you close to 13:1
Old Aug 13, 2003 | 12:58 PM
granada_sun's Avatar
http://www.c-speedracing.com/h...c.php
with itr head/block/piston to deck height and .014 for head gasket thickness (to compensate for the .015 mill with stock head gasket)....
compression ratio would be around 12.2-12.4
Old Aug 13, 2003 | 01:36 PM
Default Re: (granada_sun)
C-speed is off by .3- remember that....
Old Aug 13, 2003 | 04:47 PM
the question is which .3 higher or lower....but still not quite 13:1.
that can be the difference between pinging or not with 92-93 octane pump gas.
Old Aug 13, 2003 | 07:14 PM
JDMHN8's Avatar
Default Re: (advanracing62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">C-speed is off by .3- remember that....</TD></TR></TABLE>
I put a stock USDM GSR through it and got 10:1, a USDM LS and got 9.2:1.
I would think it's pretty accurate, but maybe custom combos throw it off?
Old Aug 13, 2003 | 07:39 PM
Default Re: (JDMDA9)
it's only off on the PCT pistons. I think it's .3 low
Old Aug 14, 2003 | 12:49 AM
igotyofire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">it's only off on the PCT pistons. I think it's .3 low</TD></TR></TABLE>
So your saying CTR pistons in a b18c with a b16 head or itr head dont yield 11.77 compression and more like 12.1 ? with a 3 layer oem head gasket? how do u know its .3 low?
Old Aug 14, 2003 | 08:55 AM
Default Re: (igotyofire)
lots of testing, and time.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">
So your saying CTR pistons in a b18c with a b16 head or itr head dont yield 11.77 compression and more like 12.1 ? with a 3 layer oem head gasket? how do u know its .3 low?</TD></TR></TABLE>
Old Aug 14, 2003 | 11:58 AM
igotyofire's Avatar
so is 12.1 correct? i want to know
Old Aug 14, 2003 | 12:59 PM
Casey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">so is 12.1 correct? i want to know</TD></TR></TABLE>
its higher than that. SGT on the board knows around what it should be. I trust him more than c-speed racing. He knows more about b series engines than i know about myself
Old Aug 14, 2003 | 01:19 PM
KRiS1's Avatar
How about with JDM ITR pistons and the Mugen head gasket? About 11.5 or so?
Old Aug 14, 2003 | 01:39 PM
Casey's Avatar
yeah, that sounds right, and thats without milling the head of course
Old Aug 14, 2003 | 02:02 PM
KRiS1's Avatar
Now here is a stupid question:
I think Im going to go with JDM ITR pistons with mugen/spoon headgasket. Can I get by with just ordering them in the standard size or do I need to get .25 over and rebore/hone the block? Also do I have to change the bearings? The motor is pretty new :2001 USDM B18C5 w/ ~30k
Old Aug 14, 2003 | 02:07 PM
Casey's Avatar
it depends on if your cylinder walls have been scratched or not. either way youll probably need to hone the walls, but ill let someone that knows more than i do answer your question
Old Aug 14, 2003 | 04:39 PM
If you're going to pull the bottom end apart, might as well throw in new bearings....add a lil comfort and security to the build
speedracer209
Aug 17, 2006 01:10 AM
PinkMaggit
Dec 17, 2005 10:09 PM
JDM978
Oct 10, 2004 10:31 AM
QuanKwan
Feb 29, 2004 11:03 AM
dwn-shift
Jun 24, 2003 07:19 PM
