Compression with CTR pistons?
Old Feb 28, 2004 | 02:39 PM
QuanKwan's Avatar
Default Compression with CTR pistons?
One a stock B18C5 motor, oem headgasket with stand bore CTR pistons, anyone know what the compression is?
I heard C-Speed Racing website calculation is all wrong so I'm not relying from them.
Old Feb 28, 2004 | 02:56 PM
b18c-rDC2's Avatar
Default Re: Compression with CTR pistons? (QuanKwan)
approx. 12:1, according to sgt the ctr piston sits .030 higher than any other b series pistons when comparing piston to deck height....If I remember correctly sgt approximates around 12:3:1....hope this helps...
Old Feb 28, 2004 | 03:02 PM
QuanKwan's Avatar
12.3? sounds good thnks
Old Feb 29, 2004 | 12:18 AM
DC2 Pimp's Avatar
Default Re: Compression with CTR pistons? (b18c-rDC2)
It is approximately 12:1 with a stock head gasket and that is if your head has not been milled down.
Old Feb 29, 2004 | 12:46 AM
Kendall's Avatar
Were SGT's measurements taken with the PR3 head or the P72 head? And it was a P72 block, with the 1.8 VTEC crank I'm assuming, right?
Old Feb 29, 2004 | 09:51 AM
Pondus's Avatar
Default Re: (Kendall)
For an answer check this out: https://honda-tech.com/zerothread?id=717928
Old Feb 29, 2004 | 11:03 AM
allm0torGSR's Avatar
Compression calculator:
http://www.bojangs.com/calculator
speedracer209
Aug 17, 2006 01:10 AM
PinkMaggit
Dec 17, 2005 10:09 PM
Spyderman4g63
Apr 27, 2005 01:23 PM
junjun
10
Sep 12, 2001 06:48 AM
ITR111
Aug 31, 2001 02:19 PM
