Top of wastegate hitting Ac line..
Old Aug 13, 2003 | 11:02 AM
B18c1turboedEK's Avatar
Default Top of wastegate hitting Ac line..
I have a tial wastegate 35mm and the top of it is hitting one of mu Ac line.. does the top get hot enough to melt my ac lines?
I dont see how it can because its where the spring sits so does it get that hot ??
Please let me know.
If not u know where i can get the little elbow to turn my wastegate at , so i can put the wastegate on sideways???
Old Aug 13, 2003 | 11:06 AM
quikB18B's Avatar
Default Re: Top of wastegate hitting Ac line.. (Koticcivic4u)
Revhard sells the elbows, or cody (tinker219) can make you one.
Old Aug 13, 2003 | 01:19 PM
Foozball26's Avatar
Default Re: Top of wastegate hitting Ac line.. (quikB18B)
you should be able to pull the a/c line back a little away frm the wastegate.
You may have to bend it, just don't kink it and you'll be fine.
Secure it with some zippe ties etc.
Old Aug 14, 2003 | 01:50 PM
anothaRRR's Avatar
Wrap some duck tape around it and you are good to go.
Old Aug 14, 2003 | 03:03 PM
NeEd4Spe3d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Revhard sells the elbows, or cody (tinker219) can make you one.</TD></TR></TABLE>
I just bought a rev hard elbow and it is anlged where you will still be hitting something.. thats what happen to mine. I believe with my tial on I'll be touching the mounts next to the ac.
Old Aug 14, 2003 | 03:34 PM
AlphaKennyWun's Avatar
Default Re: Top of wastegate hitting Ac line.. (KanMan)
the constant shifting of the motor back and forth and the wastegate pulling and pushing on the ac line can loosen the crimps on the A/C hose and cause it to leak over time. After it did to mine i took the hose off and had a local a/c shop fabricate a longer custom hose using the parts from the exisiting hose for like $50. worked out good
Old Aug 15, 2003 | 05:17 AM
Default Re: Top of wastegate hitting Ac line.. (anothaRRR)
Ok thanks guys.....
b16turbosi
Mar 10, 2005 04:25 PM
abmerop18
Feb 2, 2005 06:19 PM
killa_lude
Oct 1, 2003 04:59 AM
GeorgeJetson
Jun 12, 2003 12:58 PM
AP-Signworks1
Jun 4, 2003 11:02 AM
