Torque spec for header installation
Hi,
I've got the header in place and all ready to go. I wanted to double check what the appropriate torque is for the head to exhaust manifold and exhaust manifold to cat. Thanks!
Can't wait to go for a drive...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">imo use anti seize and just hand tight.</TD></TR></TABLE>
hand tight - they'll back out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
hand tight - they'll back out. </TD></TR></TABLE>
Mine are hand tight and haven't backed out yet
The header/cat. connection shouldn't leak as long as there is decent tension on the springs, the gasket is in good shape, and everything is lined up properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EbboyPSi »</TD></TR><TR><TD CLASS="quote">
Are they really "hand" tight or did you use a wrench.
</TD></TR></TABLE>Are they really "hand" tight or did you use a wrench.
Thanks!
I just wanted to make sure and get it right, as I heard some people have caused "cracks" in the header near the collector from over tightening...
Are they really "hand" tight or did you use a wrench.</TD></TR></TABLE>
I mean hand tight w/ a 3/8" ratchet
Hand tight w/ fingers would be worthless
. Hand tight w/ fingers would be worthless
r1de4life
Jun 2, 2006 01:06 PM
