JDM DC 4-1 collector is actually 60 mm not 2.5"
Old Aug 11, 2001 | 07:06 AM
DutchITR1689's Avatar
Default JDM DC 4-1 collector is actually 60 mm OD not 2.5"
My JDM DC 4-1 just came in. I discovered that the collector (near the O2 bung) is actually 60 mm OD. Only the last piece where the donut lies on is 2.5" OD (63.5 mm). I think the JDM 4-1 is effectively also 60 mm OD because it's double walled near the donut. Maybe, that's why all japanese aftermarket exhausts like the Mugen are 60 mm OD.
[Modified by EuroITR1689, 2:03 AM 8/12/2001]
Old Aug 11, 2001 | 07:19 AM
Benjamin Tang's Avatar
Default Re: JDM DC 4-1 collector is actually 60 mm not 2.5" (EuroITR1689)
yep it's true about the i.d. ... someone posted about this before awhile back...
Old Aug 11, 2001 | 07:25 AM
Default Re: JDM DC 4-1 collector is actually 60 mm not 2.5" (Benjamin Tang)
So, I think a 60 mm cat back should be sufficient. You don't need a 2.5" cat back with this header (and the JDM, Mugen etc.)? Don't know about the Hytech header......
Old Aug 11, 2001 | 09:38 AM
D's Avatar
D
2.5" (63.5mm) is the OD of the piping if i'm not mistaken... nominal ID of such piping is going to be smaller, so, 2.5", 60mm.... same ballpark.
D
Old Aug 11, 2001 | 11:35 AM
sgT's Avatar
sgT
Default Re: JDM DC 4-1 collector is actually 60 mm not 2.5" (D)
D,
The OD of the end which has an anti reversion area is 2.5 but the actual
exh pipe inside as he said was 60mm OD. Which matches the OD of
said japanese exh systems.
Old Aug 11, 2001 | 03:44 PM
Default Re: JDM DC 4-1 collector is actually 60 mm not 2.5" (sgT)
Yeh. I am only talking about the OD, not ID.
Old Aug 11, 2001 | 04:05 PM
Racer-X's Avatar
Most JDM aftermarket headers for our cars sold in Japan are all the std 60.5mm which is 2.381inches
Which in it's self is not 2.5 inches unless maybe your counting outside dia.
2.5inches dia = 63.5mm
next std piping size seen alot if 70mm = 2.755inches
and if the outside dia is 60mm which is a dia of 2.362 in inches.
The actual inside dia is probably around 2.32-3 inches, but that just est...becuase unless you know the actual thickness of the piping they used..you can only guess at it.
Old Aug 11, 2001 | 05:20 PM
D's Avatar
D
aah, werd. i can't read very well these days....
Old Aug 12, 2001 | 07:01 PM
SMSP's Avatar
Default Re: JDM DC 4-1 collector is actually 60 mm OD not 2.5" (EuroITR1689)
Wow, lots of numbers in this post. Here are my measurements of the ITR JDM header.
ID of Inner Tube of Collector 2.160"
ID of smallest part of collector 2.118"
OD of outer collector tube 2.55" or 65mm
Tube OD 1.688" (probably like a 43mm spec tubing)
The ITR JDM, Toda and Spoon headers have a 65mm (2.55") OD collector, not 63.5mm. The Toda has a double walled collector but not like the ITR JDM which has the anti reversion chamber so there is a gap between the inner and outer tubes. The Toda header's inner tubing is in contact with the outer tubing so it's effective ID is greater than the ITR JDM header. The DC JDM 4-1 has a 2-1/2" OD collector and is probably 16g material so it's ID is 2.370".
The Mugen is a 60mm OD system however I've read the muffler necks down to 2-1/4" OD tubing, or maybe somebody measured the ID of the muffler and got 2-1/4" and this is where this info started. I don't know what Mugen uses in their muffler, but 60mm OD tubing will measure very close to 2-1/4" ID.
60mm systems do fairly well on the car however US spec cats are 2-1/2" ID and when you bolt up a 60mm (2.36") OD/2.25" ID system to a cat with an ID of 2-1/2" you have a 1/8" wide lip all the way around the B pipe joint/flange which will cause turbulence.
SMSP-Who wishes a moderator would archive this information
Old Aug 13, 2001 | 01:44 AM
Default Re: JDM DC 4-1 collector is actually 60 mm OD not 2.5" (SMSP)
Wow, that's indeed a lot of numbers. Thanks.
What I want to say is that the DC JDM has a bottleneck in the collector near the O2 bung/connection. It's 60 mm OD there. I expected it to be 63.5 mm OD. You agree with this?
Old Aug 13, 2001 | 05:24 AM
SMSP's Avatar
I haven't seen a DC JDM so I'll take your word on that. But, I can confirm the 2-1/2" measurement at the donut area since that is what DC told me on the phone. BTW, I wouldn't classify reductions in tube size in the collector as a bottleneck.
Old Aug 13, 2001 | 05:48 PM
PY2KITR1060's Avatar
I can confirm that with my accurate measure of my recently received JDM DC 4-1
The following are taken at the collector at the very donut end of the header. I don't care about the size of any other section:
OD = 64mm
ID = 61mm
I notice my collector is not a PERFECT circle and that's why the measurement is not exactly 2.5inch.
SMSP, did you received my email about the cat order? Can you just send me an mailing address so i can send you my payment? IM is fine too. Thanks for taking the time.
Henry
Old Aug 13, 2001 | 07:10 PM
SMSP's Avatar
Default Re: JDM DC 4-1 collector is actually 60 mm OD not 2.5" (PY2KITR1060)
I just did a search on this email adress henrycheang@hotmail.com and didn't find anything, so I guess I didn't get one. I had one customer who couldn't get the 2-1/2" donut on his DC JDM, I suspect it was due to an oval collector tube.
SMS Products
6016-D McDaniel Lane
Charlotte, NC 28213
For a little while longer.
After the move I'll concentrate on getting the web site up and running http://www.sms-products.com
ziich2
Jun 18, 2007 12:57 PM
DeL SLo
Sep 25, 2004 06:31 PM
SiShane
Jul 23, 2004 02:17 AM
Toda Party
Oct 10, 2001 11:54 PM
rsx03
Aug 15, 2001 04:22 PM
