1994 Civic Cx Code 41 o2 primary heater.......... Reward inside, if helped
Old Aug 13, 2003 | 04:47 AM
JdmVetteEater
Guest
Posts: n/a
Default 1994 Civic Cx Code 41 o2 primary heater.......... Reward inside, if helped
Ok, I had the stock 1 wire o2 in there and it was throwing the code for a year, but over looked it, I have a p28 ecu in my car with the 1.6 sohc motor in it.... I was told to hook the four wire o2 up, so i did, wired it up just like a stock civic ex, well it is still throwing the code, and now Neither of my two air fuel gauges work, it is getting no signal, I know for a fact this o2 is good.... Any suggestions????? I dont know if this will help but when i am cruising my speedometer needle jumps back and forth a little..... Thanks for any information, and I have searched.....
Your reward if you help me is, you are my new best friend.....
Old Aug 13, 2003 | 05:33 AM
chad's Avatar
Moderator
Default Re: 1994 Civic Cx Code 41 o2 primary heater.......... Reward inside, if helped (JdmVetteEater)
you didn't hook it up right.....go back over your wiring....
Old Aug 13, 2003 | 05:36 AM
Maintenance's Avatar
so your a/f ratio gauge worked before you converted it to a 4 wire o2 sensor?
Old Aug 13, 2003 | 05:39 AM
JdmVetteEater
Guest
Posts: n/a
Default Re: 1994 Civic Cx Code 41 o2 primary heater.......... Reward inside, if helped (racerxfear)
yes it did work before i put the new one in, and I followed the Helms manual as far as the wiring goes, so if Helms is right I am right, if they are not right then I am not right, you tell me...
Old Aug 13, 2003 | 05:46 AM
kay this is how i did mine since mine was originaly a single wire o2 i had to convert it to 4 wire... so i had to add three more...
1. white wire- since that was already prewired to d14 of the ecu and corresponded with the p13 ecu i left that
2.orange/black this was the wire off the 4 wire o2 sensor which i just ran that to a6 the ecu wiring it will be orange/blk
3.green/white that's suppose to go to d22. but i've just splice into the grn/wht wire to the tps sensor. the grn/wht of tps sensor also runs into d22 so no point of running another wire into the ecu
4.yel/blk this i splice into a 12v source when the ignition is on
i also follow the helms this what i did. check and see if this how you did it too
Old Aug 13, 2003 | 06:41 AM
JdmVetteEater
Guest
Posts: n/a
Thanks for the very informationsl post, I will check that out, but guys keep throwing ideas my way..... I am apreciate, the post abouve....
Old Aug 13, 2003 | 09:07 AM
JdmVetteEater
Guest
Posts: n/a
any more.....
Old Aug 13, 2003 | 09:17 AM
ATS*JSJ EK9's Avatar
when i was throwing code 41 i thought is was my o2. i replace it 3 time. then it was still throwing code 41. at the end. my friend fig out it was my ecu. it was burnt..
btw this was in a 92 hatch si. try and barrow another p28.they go for 100-150
Old Aug 13, 2003 | 09:36 AM
JdmVetteEater
Guest
Posts: n/a
Default Re: 1994 Civic Cx Code 41 o2 primary heater.......... Reward inside, if helped (JSJ EK HATCH)
Tired the toher ecu, still throwing the code.....
Old Aug 13, 2003 | 11:02 AM
JdmVetteEater
Guest
Posts: n/a
bump for trying to make it run right
Old Aug 13, 2003 | 02:05 PM
JdmVetteEater
Guest
Posts: n/a
Default Re: (JdmVetteEater)
bump
Old Aug 13, 2003 | 02:31 PM
chad's Avatar
Moderator
YOUR WIRING IS not hooked up correctly!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! have you rechecked it yet???
JD95hatch
May 18, 2006 02:51 PM
Mike K
Feb 3, 2006 07:17 PM
turboxsi
Oct 27, 2003 04:33 AM
5STAR3
Aug 31, 2003 09:42 AM
SuperTeg95
Mar 25, 2003 07:04 PM
