SRS Reel removal question
Old Aug 12, 2003 | 08:28 PM
jdmspoonitr's Avatar
Default SRS Reel removal question
Well I'm putting in the Momo Corse now that my other wheels have sold. I am taking off the SRS reel.
The blue wire disconnects easily, but what about the other bundle of wires? They don't seem like they clip in, so how do I remove it without cutting anything?
Old Aug 12, 2003 | 08:50 PM
bus stop's Avatar
Default Re: SRS Reel removal question (jdmspoonitr)
you should see a yellow connector under the dash.....just follow the wire from the srs reel and you will reach it.
fyi...that yellow connector is a "spring-load" type. You will need sometimes as well as patient to unlock it.
I usually will remove the yellow connector from the holding clip (white color) first, it will give you more room to unlock it.
Old Aug 12, 2003 | 08:53 PM
Dr Pooface's Avatar
Default Re: SRS Reel removal question (WhosITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhosITR &raquo;</TD></TR><TR><TD CLASS="quote">you should see a yellow connector under the dash.....just follow the wire from the srs reel and you will reach it.</TD></TR></TABLE>
Yup. That ones a bitch.
Old Aug 12, 2003 | 09:07 PM
Default Re: SRS Reel removal question (Dr Pooface)
Okay now I removed the SRS reel. But I was wondering something for people with aftermarket momo wheels. When you lined up the hub, where was the top symbol pointing???
When I make the hub indentation completely horizontal, the arrow points up and to the left. From looking at it, it really shouldn't make a difference what way the arrow is pointing right?
I'm trying to figure out whether I got the right hub or not.
DeDonDeRosa
Oct 15, 2007 05:29 PM
JDM-EJ1
12
Dec 30, 2005 03:02 PM
rukawa1one
Jun 18, 2005 04:09 PM
citanest
Feb 28, 2002 11:03 AM
