any b16's using toda camshafts SPEC C?
Old Aug 12, 2003 | 07:52 PM
yellowmonkeyboy's Avatar
Default any b16's using toda camshafts SPEC C?
streetable?
how do you like it?
what other mods do you have?
times?
Old Aug 12, 2003 | 08:15 PM
Drag R's Avatar
Default Re: any b16's using toda camshafts SPEC C? (yellowmonkeyboy)
alot of people using them, but not in a B16. its kinda pointless, there capable of so much more power in a bigger displacment motor..
nick
Old Aug 12, 2003 | 08:33 PM
Mr.Integra's Avatar
Default Re: any b16's using toda camshafts SPEC C? (Drag R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R &raquo;</TD></TR><TR><TD CLASS="quote">alot of people using them, but not in a B16. its kinda pointless, there capable of so much more power in a bigger displacment motor..
nick</TD></TR></TABLE>
you do realize.. that toda cams were originally made for b16s right..?
Old Aug 12, 2003 | 08:43 PM
thegrinch's Avatar
they work pretty well if you are running enough compression. I have seen some really good numbers. actually better than some of the bigger displacement cars and they also love the higher rpm range as well.
Old Aug 13, 2003 | 05:38 AM
Drag R's Avatar
Default Re: any b16's using toda camshafts SPEC C? (Mr.Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra &raquo;</TD></TR><TR><TD CLASS="quote">you do realize.. that toda cams were originally made for b16s right..?</TD></TR></TABLE>
ok, but is worth putting all that money into a motor that will only produce 200whp if that, fully built. You can use ctr cams/pistons in a b18c and roast b16 with C's anyday.
"There is no replacement for displacement"
nick
Old Aug 13, 2003 | 09:07 AM
AussieK24's Avatar
Whilst Toda cams were originally made for B16's, the C was developed for the 1800's. It really is a bit much for a streetable 1600 IMHO
MightyMouseTech
Oct 28, 2007 04:55 PM
Allmota O
10
Feb 10, 2006 07:25 PM
hcar
Mar 4, 2005 12:30 PM
TRF #001
19
Oct 14, 2004 08:14 PM
Drag R
17
Aug 5, 2003 07:37 AM
