Jdm rear upper control arms
Old Aug 10, 2001 | 09:11 PM
Rhetoric's Avatar
Default Jdm rear upper control arms
How much of a significance are they to use over Itr/Gsr rear uppers? I noticed their construction is more like a tube? Are they worth the upgrade?
Old Aug 10, 2001 | 10:58 PM
EPGONZALEZ's Avatar
Default Re: Jdm rear upper control arms (G S R)
yes they are worth the upgrade..if you have a lowered suspension..get an adjustable one..
Old Aug 10, 2001 | 11:46 PM
Rhetoric's Avatar
Default Re: Jdm rear upper control arms (EPGONZALEZ)
Adjustable rear upper arm? What would you recommend?
Old Aug 11, 2001 | 12:57 AM
COREY ITR#625's Avatar
Mike at IPS sells them (JDM rear upper control arms) for around $100 and he told me that they make a significant difference in handling. I have yet to get them though.
Old Aug 11, 2001 | 01:37 AM
B18C5's Avatar
Default Re: Jdm rear upper control arms (COREY ITR#625)
If you sold something would you say it's insignificant? What is functionally different about the arm? Is it just the arm it's self or is it the bushings? Either way get the Ingalls ones. At least those add functionality rather than add JDMness.
Old Aug 11, 2001 | 07:11 AM
Zeus's Avatar
Default Re: Jdm rear upper control arms (B18C5)
The USDM upper arms give more neg. camber than the JDM ones... in a sense, they assume that the average US driver can't drive for ****! Your car will rotate a little better due to less neg. camber...
Old Aug 11, 2001 | 07:26 AM
Benjamin Tang's Avatar
Default Re: Jdm rear upper control arms (Zeus)
huh? all this time i thought the jdm upper arms had more NEGATIVE camber... doh.
i used to have ingalls rear adj. control arms.... what a piece of crap. not only were they noisy, but on one side the bushing fell out and i had one wheel partially collapse on me
Old Aug 11, 2001 | 08:08 AM
SpecR_EK's Avatar
New User
Default Re: Jdm rear upper control arms (Benjamin Tang)
I thought the only difference was the JDM upper control arm being beefier than the USDM one. The on the USDM ITR is like the one used on the GSR.
Old Aug 11, 2001 | 08:51 AM
Asahi's Avatar
Default Re: Jdm rear upper control arms (SpecR_EK)
King Motorsports has some of the nicest adjustable rear upper arms I have seen. with adjustability it wll not only be a matter of more or less but EVEN camber.
Old Aug 11, 2001 | 05:57 PM
Rain_man's Avatar
New User
Default Re: Jdm rear upper control arms (Carlex)
You weren't kidding they were nice.
http://www.kingmotorsports.com/produ...g/rear_uca.jpg
But dang at 375 thats hard to swallow...
I bet you could make those your self if you could get your hands on the parts.
00 FBP ItR
Jan 27, 2004 12:45 PM
ActiveAero
Mar 6, 2002 02:18 PM
