What tire for stock steelies??
Old Aug 12, 2003 | 02:54 PM
fishnfst's Avatar
Default What tire for stock steelies??
Wondering what tire and size you would put onto some stock 14" steelies for solo II? I saw that yokohama makes their ao32 in a 195/60/14. What other options are out there? Is there anything in the stock size that would work also?
TIA
Old Aug 12, 2003 | 03:20 PM
isotopesope's Avatar
Default Re: What tire for stock steelies?? (fishnfst)
the falken azenis also come in 195/60-14. i personally use the azenis for autocross and absolutely love them. i would stick with the 195/60-14 size no matter which tire you go with. the sidewall will be a bit smaller and the footprint wider, also the diameter between the two are almost identical. plus, my 205/50-15 azenis are more like 213 or 215 wide. i don't know if the 14" ones are also wider... the azenis are also cheap:
http://www.vulcantire.com/azenis_t.htm
this might also be usefull in comparing your stock tire size with other sizes:
http://www.miata.net/garage/tirecalc.html
hope that helps.
JackSparrow
Dec 6, 2008 08:45 AM
accordinglyevil
Nov 19, 2007 06:34 PM
Maireeka
Mar 26, 2007 08:05 AM
Beach Accord
Feb 1, 2004 08:57 AM
