ITR Rear Sway on Civic EX
Old Aug 12, 2003 | 12:05 PM
DaNish's Avatar
Default ITR Rear Sway on Civic EX
will an integra type r rear swaybar fit on a 4dr civic ex?
would i need integra bushings to make it fit...any comments would be appreciated
Old Aug 12, 2003 | 12:07 PM
Spade's Avatar
Default Re: ITR Rear Sway on Civic EX (X DaNish X)
What year Civic?
You will need the integra mounts and a beaks or BSQ kit to prevent your subframe from tearing.
Old Aug 12, 2003 | 12:47 PM
DaNish's Avatar
Default Re: ITR Rear Sway on Civic EX (Spade)
95
Old Aug 12, 2003 | 12:50 PM
Spade's Avatar
Er you need LCA's to then.
Old Aug 12, 2003 | 02:45 PM
DaNish's Avatar
bah, ok...what would be the best upgrade as far as rear sway bars go for my car?
Old Aug 12, 2003 | 03:04 PM
KRiS1's Avatar
didn't the 4 door EX's come with a rear swaybar?
Old Aug 12, 2003 | 03:17 PM
DaNish's Avatar
Default Re: ITR Rear Sway on Civic EX (POS Hatchback)
yea they did, but i want to upgrade
plus its not connected right now b/c my friend fucked up the LCA where the bolt connects to the sway bar and the piece that holds the sway bar to the LCA, i think its a bushing is shot
Old Aug 12, 2003 | 03:20 PM
KRiS1's Avatar
If your LCA's are messed up you could always get a new set. i have the SRR LCA's with the Beaks kit and really like it.
Old Aug 12, 2003 | 03:26 PM
ATS*Mark's Avatar
OG triple OG
dude if your car came with a sway bar than you can put the itr one on , but get the beaks kit or youll be sorry
Old Aug 12, 2003 | 03:30 PM
DaNish's Avatar
Default Re: ITR Rear Sway on Civic EX (TURSpoonEK)
the LCAs aren't messed up, its just the hole that connects the LCA to the swaybar is messed up, he stripped the bolt and now he has to tap the hole to get the bolt through it. Plus the left piece that connects the swaybar to the LCA is shot. I thought they were called bushings, but maybe i'm wrong. I didn't wanna spend that much money on a swaybar, just something that is better than stock
Old Aug 12, 2003 | 03:32 PM
muse's Avatar
It sounds like he needs new LCA's too since his boy fu$#ed em up.
I've got a 96 spec JDM ITR sway laying in my garage w/ bushings and clamps. I would definately recommend the beaks kit if you do go with any larger than stock rear swaybar.
does anyone know for sure if the balljoint mounting hole is in the same location on the EG rear LCA and ITR rear LCA?
Old Aug 12, 2003 | 03:35 PM
DaNish's Avatar
Default Re: ITR Rear Sway on Civic EX (muse)
how much is the beaks kit and what exactly is it?
Old Aug 12, 2003 | 03:36 PM
KRiS1's Avatar
http://www.beaksproducts.com/eg-quickswap.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X DaNish X &raquo;</TD></TR><TR><TD CLASS="quote">how much is the beaks kit and what exactly is it?</TD></TR></TABLE>
Old Aug 12, 2003 | 03:40 PM
DaNish's Avatar
so that kit comes with the itr rear swaybar and everything i need to install it on my car?
do i need new LCAs?
Old Aug 12, 2003 | 03:49 PM
DaNish's Avatar
do i need new LCAs to make it fit or no?
Old Aug 12, 2003 | 05:42 PM
ATS*Mark's Avatar
OG triple OG
if your lca's are fucked then yes you do , and since you have a 5th gen id recomend getting itr lca's too
the beaks kit for me including everything was 180 , that was shipped with endlinks
Old Aug 12, 2003 | 06:21 PM
KRiS1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">if your lca's are fucked then yes you do , and since you have a 5th gen id recomend getting itr lca's too
If he goes with ITR LCA's won't he have to go with ITR struts in the rear also?
Old Aug 12, 2003 | 06:22 PM
Mr. Choi's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">
If he goes with ITR LCA's won't he have to go with ITR struts in the rear also?</TD></TR></TABLE>
yes
Old Aug 12, 2003 | 06:46 PM
ATS*Mark's Avatar
OG triple OG
Default Re: ITR Rear Sway on Civic EX (Mr. Choi)
mr choi , could that be eric choi?
Old Aug 12, 2003 | 06:47 PM
ATS*Mark's Avatar
OG triple OG
if you have eyebolt rear suspension then you dont , but you prolly dont
Old Aug 12, 2003 | 09:22 PM
DaNish's Avatar
im keeping the stock LCAs, they're not fucked up
it says on the beaks site that the Civic EX Sedans LCAs are compatible with the sway bar
Old Aug 17, 2003 | 11:55 PM
Mr. Choi's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">mr choi , could that be eric choi?</TD></TR></TABLE>
no. you wont need new lca for an itr bar. it'll fit. use SI endlinks tho.
wait EX civic's came with rear bar? i though only on si. la;ksd g
Old Aug 18, 2003 | 06:29 AM
DaNish's Avatar
it says directly on the site that it will fit a Civic EX sedan with everything they give u in the package
VBitter
Oct 11, 2009 06:10 PM
krazy one
Suspension & Brakes
25
Sep 22, 2007 06:46 PM
Odiedogcx
Suspension & Brakes
Nov 18, 2005 05:42 PM
KRiS1
May 20, 2002 04:21 PM
