Old Mar 25, 2015, 11:07 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
cleaning carbon deposits
Old Aug 10, 2001 | 04:10 PM
mercury's Avatar
New User
Default cleaning carbon deposits
Has any had experience using Mopar Combustion Chamber Conditioner to remove the carbon deposits off the valves and piston tops?
How well does it work? Adverse affects? Cost?
Old Aug 10, 2001 | 06:07 PM
bb6h22a's Avatar
Default Blah...
..just take a some automatic transmission fluid, fill a shallow bowl w/ it, unplug a vaccum line on your intake manifold and let a little go in, slowly. Yes, while the motor is running. It will smoke, a lot, so make sure your in a well ventilated place! But, it will clean out those deposits, it's an old time hot-rod trick.
Dont trust me, ask around on some other forums, like v8 forums!
Old Aug 10, 2001 | 07:17 PM
BreakStuff's Avatar
New User
Default Re: Blah... (bb6h22a)
Thats cool bb6h22a, never heard that one before..
I have tried a Chevy Top End Engine Cleaner, Just pour it down the intake, spin the motor over manually a few times to get the fluid into the piston chambers, let it soak for a few hours..... and yeah, This way is gonna make a whole lotta smoke as well!
Old Aug 13, 2001 | 10:33 AM
976's Avatar
976
New User
Default Re: Blah... (Teken)
Some hot-rod guys in my town do it more than often, pisses a lot of people off. Fire trucks run all over the place, but no fire...
Old Aug 13, 2001 | 10:49 PM
samiam's Avatar
Default Re: cleaning carbon deposits (mercury)
Yep, the good old GM top engine cleaner does it.
Old Aug 14, 2001 | 08:39 AM
TurboMiata's Avatar
Default Re: cleaning carbon deposits (samiam)
Speaking of GM top engine cleaner, using the spray can GM Top engine cleaner is an easy way to not hydrolock the motor
Old Aug 15, 2001 | 07:37 PM
hioctane3's Avatar
Is that something good to do with a high mileage car? I have 136,000 on my 94 Teg.
Old Aug 16, 2001 | 07:50 AM
AMSOIL89LXi's Avatar
New User
You may want to try AMSOIL Power Foam. Just spray it directly into the throttle body. Full instructions are on the can. I've done this several times on my 89 Accord LXi and the return in performance was pretty amazing.
Old Aug 23, 2001 | 08:16 PM
mercury's Avatar
New User
I've got 2 15oz cans of GM Top Engine Cleaner ($10 ea at my local Chevrolet dealer). Where's a good place to slowly pour this stuff in so that it gets evenly distributed through all 4 cylinders?
To clean the carbon deposits off the tops of the pistons, I'm also considering pouring this stuff through the spark plug holes, letting it sit for 7 hours, then sucking it out with a suction gun (to prevent hydrolock). Any reason not to do this?
Old Aug 24, 2001 | 12:16 PM
GSRMatt's Avatar
25 Year Member
For MCCC info, read this:
http://www.vfaq.com/mods/MCCC.html
dleccord
Apr 16, 2008 10:21 AM
gldndrgn14
Jun 20, 2005 04:01 AM
sporkcrx
Jan 11, 2004 07:59 AM
Blaze45
Jan 25, 2003 01:02 PM
