Help me pick a suspension pls
Old Aug 11, 2003 | 05:53 PM
bostonegcivic's Avatar
Default Help me pick a suspension pls
I've been researching suspensions for a while and have found it difficult to determine what would be a good setup and would like your input. I have a 93 DX daily driver. I have ST sway bars 19mm f/r with upper front strut tower bar. I am looking for a slight to moderate increase in handling and cornering, but want to avoid a harsh ride, and would prefer at most a 1.5 inch drop. Are there any setups you could recommend that fit this criteria? TIA
Old Aug 11, 2003 | 07:45 PM
Dancing is Forbidden's Avatar
Default Re: Help me pick a suspension pls (bostonegcivic)
Tein SS
Old Aug 11, 2003 | 08:51 PM
Andres-eh2's Avatar
Default Re: Help me pick a suspension pls (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Tein SS</TD></TR></TABLE>
With 94+ Integra Spring Rates
Old Aug 11, 2003 | 10:21 PM
WangChung's Avatar
Default Re: Help me pick a suspension pls (EGEESIX)
Tokico 5-ways with GC 450/350 rates. put the 450 out back, so there will be no understeer what so ever.
Old Aug 12, 2003 | 04:28 PM
Default Re: Help me pick a suspension pls (97civhatch)
Those all sound like reasonable suggestions. What do you all think of combining H&R springs with KYB AGX. Would that accomplish the same goals but for less money?
Old Aug 12, 2003 | 04:31 PM
gezer's Avatar
that sounds like a good setup ya they would accomplish alot for alot cheaper
Old Aug 12, 2003 | 04:44 PM
97civicdx's Avatar
get lowering springs for an integra, they are a direct fit. You better be planning a swap with the higher spring rate u will get. Good luck
Old Aug 14, 2003 | 05:21 PM
Default Re: Help me pick a suspension pls (97civicdx)
good point - how do i figure out which spring rate to get - is there some formula based on the weight of the car that tells you or is there some other way?
Old Aug 15, 2003 | 01:27 AM
97civicdx's Avatar
teg springs are going to be stiffer in a civic due to the tegs heavier weight vs a civic's lighter weight.
Old Aug 15, 2003 | 01:45 AM
Ziggie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bostonegcivic &raquo;</TD></TR><TR><TD CLASS="quote">What do you all think of combining H&R springs with KYB AGX. Would that accomplish the same goals but for less money?</TD></TR></TABLE>
This is one of the best shock/spring combo's IMO. You'll get a 1.5 drop and better handling. The KYB AGX has MANY different adjustments so you can control the stiffness of your ride from harsh to smooth. Some Koni's are also adjustable but to adjust them you have to take the shocks out whereas with the KYB AGX you can just turn the dials.
As for the springs there are lots of good springs that drop about 1.5. H&R sports are good. I'm using Neuspeed springs with KYB AGX shocks. You just need to decide the right spring rate and how much you want to drop your car when choosing springs.
These setups usually average from $500 for the everything. Also they are very good for auto crossing if you are into that and daily driving as well.
Now if you have more money and are willing to spend $750+ then go for the Teins...
Good luck and let us know what you pick.
Old Aug 21, 2003 | 04:59 PM
Default Re: Help me pick a suspension pls (Ziggie)
Yep, I think I'm going to go that route, but I need to do more research on which springs will give me the 1-1.5 in drop, costs, and appropriate spring rates. Thanks for the help.
masaaki86
Feb 9, 2007 11:57 PM
a1320addict
Suspension & Brakes
Apr 12, 2005 06:25 AM
b18bme
Jun 15, 2004 04:54 PM
hdueceduece
Apr 10, 2004 12:46 AM
Ponyboy
Mar 28, 2002 12:33 PM
